C63 AMG (W204) 2008 - 2015
Rear rubbing issues: 19" 275s ET50 w/ H&R Springs
Old Mar 12, 2011 | 08:53 PM
dleung22's Avatar
W204 C63 /// E92 M3
Hi Everyone,
I have just slapped on my new wheels and I am experiencing rubbing issues in the rear at highway speeds under compression or when I have slight turns on uneven roads on highways.
My rims are currently 19 x 9.5 in the rear with offset ET50 on bridgestone RE11 running 275 and lowered on H&R Springs. I have already used Mercedes part spring pad #4 instead of #3 for the rears to avoid it being too low.
Is there any quick fix for this issue? even thicker spring pad (if available)?
Please advise everyone! Thanks alot!
P.S. Pictures to come later!!
Old Mar 12, 2011 | 09:21 PM
JeffDL's Avatar
C63
a more rounded tire like an hankook or falken might help? Tire selection is very important on these cars not all 275's are the same.
I run hankook's 275's on 19/10's et55 and have no rubbing issues.
Old Mar 12, 2011 | 09:30 PM
dleung22's Avatar
W204 C63 /// E92 M3
would me downsizing to 265 in the rear help??
thankss
Old Mar 12, 2011 | 09:39 PM
JeffDL's Avatar
C63
thankss
would probably solve everything.
Old Mar 12, 2011 | 10:03 PM
dleung22's Avatar
W204 C63 /// E92 M3
anyone had their fenders worked on? what can be down? apparently rolling fenders is not possible?
Old Mar 13, 2011 | 01:10 AM
Roswell's Avatar
2010 C63 AMG, 2009 ISF , 2002 L-Tuned IS300, 2011 ML350
I was told by my wheel company downsizing to 265/30/19 would be ideal to avoid rubbing.
Old Mar 13, 2011 | 07:30 AM
Muskoka_AMG's Avatar
2008 C63
Agreed with what was said above. However, a little rubbing never hurt.
Old Mar 13, 2011 | 08:59 AM
Roswell's Avatar
^^ hahaha... I agree Muskoka. I'm not rubbing at stock height, so I'm hoping my rubbing will be minimal once dropped. Honestly, I'd rather roll my fenders than downsizing to 265/30.
Old Mar 13, 2011 | 12:00 PM
dleung22's Avatar
W204 C63 /// E92 M3
I am going to go into the shop tomorrow to see if any fender work can be done...
dont want to waste a perfectly new set of 275s..i have a friend that had fender work done and he currently rolls on H&R springs, 20" rims w/ 10" width on 285 tires, offset of ET53
hope ET50 wont be sticking too far out...
Old Mar 13, 2011 | 04:12 PM
_AMG_'s Avatar
C63
Go with 265's, this would help alot.
Old Mar 13, 2011 | 11:48 PM
simonlam168's Avatar
c63
Suck in you have rubbing all the time
Old Mar 13, 2011 | 11:50 PM
Roswell's Avatar
simonlam, what did you do to fix your rubbing issues?
Old Mar 13, 2011 | 11:58 PM
c63
I did two things to fix the problem.
Centre Hub: Shaving 3mm off the base plates
Rear Fender: Pumping the rear fender out
Old Mar 14, 2011 | 12:02 AM
Roswell's Avatar
^^ what do you mean by pumping the fenders out? Pulling? What about rolling? Interesting, I didn't know we could pull our fenders.
I don't have enough material in my center wheel hub (around the lug holes) to shave safely.
Old Mar 14, 2011 | 06:51 AM
AMG-010's Avatar
2017 AMG C43
I had a slight amount of rubbing where rear fender meets the rear bumper, i just shaved it slightly and now it will only rub if I have 4 people in car, otherwise it's fine. I am running 285/25/20 on the rear
