Air filter and the Paper above
I just got my ecu back from Cory. I'am changing the air filters out. What is the paper looking filter in the top of the housing and do I leave it in? I need this ASAP please.
Erich |
is it the charcoal filters you are talking about... if so remove it for more power
Originally Posted by jobee
(Post 4989144)
Erich |
yea.. I did mine a while back.. i'm sure its the charcoal filters
Originally Posted by ergon
(Post 4989156)
Thought that might be what they were but wasn't sure. They're in the top half. I'm waiting your reply.
Erich |
They're gone.
What have I done now? has someone played a bad joke on the old man? I changed the filters and removed the charcoal paper filters. Car is running fine. Took the with shopping and a friend of mine for a ride. Got in it a little. On the way home the check engine light came on. Oil is OK. Should I have left the charcoal in? I have no idea what to check outside of what I've done. The ecu went in with ease. Any Ideas folks?
Erich |
the filters might not be sitting in right. i would remove them, then reinstall them and hand tighten every screw, then tighten all the screw diagonally. Should solve the problem
Originally Posted by AntsC63Coupe
(Post 4989979)
(Post 4990097)
Light is still on.
from what I have read.. 2 things to check
1 - the seating of the filters (removing charcoal should not set off the CEL) 2 - maybe you need to call cory about the ECU tune (which I also doubt) |
Sorry to hear your having issues, but lots of us have removed the charcoals with no issues at all.
but we all did what I have instructed you to do, I know all I did was pull it out |
Took out the one charcoal filter I had, slapped in K&Ns and it has been all good since...
Pulled codes PO420, PO430, and PO171. Kleemann, told me that the 171 was a bad air flow sensor which was making the other two kick out.
Zeph, my wife says you are a bad influence. I am considering taking out charcoals or switching filters.
are you using K&N filters ? I"m not sure but they maybe the culprit if its your sensor
Lots of ppl have had success but there are also others who have had CELs right after putting in K&Ns and/or removing the charcoal filters. It's almost a moot point coz you're gaining so little in messing with the air box. Out on the street, even your butt dyno won't be able to tell the difference.
(Post 4992029)
Originally Posted by khmergod
(Post 4991956)
if i'm not mistaken, AFE are dry filters, and shouldn't contaminate your sensors
(Post 4992419)
AFE makes both oiled and dry filters.
This is the oiled type.
(Post 4991956)
(Post 4992422)
That's why I pulled the K&N's and put the AFE's in. They do have oil but they claim no sensor problems.
Also weird thing was that my car only came with one charcoal filter...:nix: So my theory that removing charcoals will not cause CEL is pretty sound.... |
