C63 AMG (W204) 2008 - 2015
P30 Suspension Confirm lower then non-P30?
Old Feb 15, 2012 | 08:58 AM
E55 Bulldog's Avatar
2012 C63 Black Series, 2003 Hummer H1 KSC2, 2003 Hummer H1 HMCO, 1997 Hummer H1 HMC4, 1969 Jaguar E
Does anyone know if the P30 suspension is lower then the non-P30 cars. I know there has been talk about it but does anyone have actual confirmation that this is true.
Thanks guys.
Old Feb 15, 2012 | 10:42 AM
I am Jeff's Avatar
Steel Grey Metallic C63!!
It has been confirmed that P30's are lower than non P30's.
Old Feb 15, 2012 | 10:46 AM
Do we know by how much? 20mm ?
Im trying to do some math on 20" wheels and tires based off another forum members information on his non-P30.
I don't want to f' myself and buy a set that rubs like hell.
Old Feb 15, 2012 | 11:08 AM
noodleman's Avatar
2014 E63S Wagon
it's definitely not 20mm. it sits higher than H&R springs which lowers the car by 20mm from stock iirc.
From just looking, i honestly cannot tell the difference in ride height from a P30 to a non-p30 car.
Old Feb 15, 2012 | 01:54 PM
izzyAMG's Avatar
2019 GLC63, 2020 M2 Comp, 96 Miata M Edition & 19 Forester
I know its hard to tell but in person white (p30) is defintely lower but not by much.
Did you guys notice the bulges on the hood are different in the 2012's but that's another thread.
Old Feb 15, 2012 | 02:04 PM
rory breaker's Avatar
Yes
Left is 2012 P31, right is 2009 P30, if it helps.
Old Feb 15, 2012 | 06:15 PM
sjhugh's Avatar
C63 AMG, BMW 135i
Mate the difference between the two suspension packages probably doesn’t really matter.
What you could do is measure off half the diameter of the tyre size you are interested in onto a piece of string and mark the appropriate length. Then place one end of the string at the centre of the wheel hub and swing the other end over the top in an arc. This will show you approximately where the tyre will be in relation to your fender in elevated view.
The car needs to be on level ground, you need to take into account the additional compression of the springs when you have the weight of passengers in the car, the compression of the springs that will be caused by the up and down movement of the suspension when negotiating dips in the road and cornering etc, and remember the outer edges of the tyres are rounded so they will not be at exactly the same dimension as the centre of the tread.
If you add to this any info on tyre/rim width and rim offsets you will get a reasonable indication of where the tyre will place. If it’s touch and go, I’d use the rule that it will rub.
Old Feb 15, 2012 | 09:24 PM
jim07's Avatar
09 c63 p30 mars red
This question has been asked several times with no real answer. So I just measured my 2009 with P30 at 26 7/8" front and rear from the ground to the bottom edge of the wheel well (painted fender) dead center through the rim. That is with 50% wear on micheln pilot sports with 3/4 tank of gas. So someone measure a non P30 and we will have an answer.
Old Feb 15, 2012 | 09:54 PM
bhamg's Avatar
C63 AMG
With all due respect you probably won't, at least in any definitive fashion. In my personal experience three of us who installed Dinan Stage 1 suspensions (springs and shocks) on our otherwise stock M5 suspensions all experienced differing results (measured independent of wheel and tire considerations). IIRC the max difference between vehicles measured same-corner to same-corner was about 8mm.
Old Feb 15, 2012 | 09:58 PM
jim07's Avatar
09 c63 p30 mars red
Well if we get two or three P30s and two or three non P30 we will at least have an average difference.
Old Feb 16, 2012 | 06:24 AM
Mikegpr03's Avatar
C63
Guys I have a P30 car and the height is the pretty much the same. I can tell you that the ride is very stiff. The shocks are valved very aggressively. Anyone in Miami with a non P30 car around so we can put this myth to rest. ???
Old Feb 16, 2012 | 07:59 PM
jim07's Avatar
09 c63 p30 mars red
Would a couple non P30 cars take the measurements? Be nice to know.
Old Feb 16, 2012 | 10:37 PM
bhamg's Avatar
C63 AMG
I'll stick with what I've been told by someone who should know what he's talking about - P30 is 10mm lower than non-P30.
Old Feb 18, 2012 | 08:09 AM
Mikegpr03's Avatar
C63
Well if anyone wants to meet up see we can take some measurements and see if this actually the case.
Old Feb 18, 2012 | 10:10 AM
jim07's Avatar
09 c63 p30 mars red
All we need is a non P30 owner with a tape measure. Lets get some samples. Its not that hard!!! So if 10mm (1/2") taller for the non P30s is true it should be about 26 1/2 from the ground through the center of the rim to the bottom edge of the painted fender well. I know there are other variable but 10mm should show up as the average difference if we can get a few samples of each.
Old Feb 18, 2012 | 11:52 AM
Mikegpr03's Avatar
C63
Let's do it ! I'll get some pics and numbers today and post
Old Feb 18, 2012 | 02:33 PM
jim07's Avatar
09 c63 p30 mars red
front on cold tires 2009 P30
Rear 50 degrees - cold tires
My first measurement was off ----too many beers.
