*The all new Supercharger Lineup From Weistec Engineering including the Stage 3*
We are proud to announce our completely new supercharger system lineup for the M156 AMG's, including an all new 3.0L Twin-Screw Stage 3 supercharger system which is capable of making in excess of 1000 HP with our forged internals and engine parts.
Weistec 50 State Legal Carb Approved Supercharger System For those who are concious about the environment, and want to maintain the legal status of their AMG, this is the perfect system. With our CARB approved M156 Supercharger system, your AMG will make an astonishing 626 horsepower and 551 ft-lb torque. This system is designed to be bolted on a completely stock 63 AMG. Priced now at $13,499.99. Key Features: 2.3L Twin-Screw Compressor Module 1000hp Liquid to Air Intercooler Core High Flow Cast Aluminum T6 Hardened Lower Manifold High Flow Cast Aluminum T6 Hardened Throttle Body Inlet Y 45mm Boost Bypass Assembly Constant Mu, Delta Pressure (CMDP) Cog Drive System Billet Aluminum Cog Drive Cradle Assembly Poly Chain GT Carbon Fiber Cog Belt Supercharger Serpentine Drive Belt Hard Anodized Billet Aluminum Serpentine Idlers Johnson CM30 30 Liter/Min Intercooler Water Pump Intercooler Water Recovery Tank Cross Flow Heat Exchanger High Flow Fuel Rail System Molded Silicone Couplers Power-Steering Reservoir Relocation Assembly Weistec Engineering ECU Reflash (CARB E.O. D-691) Dyno graph shown below. http://weistec.com/images/m156sccarb.jpg CARB Approved and legal in 50 states! http://weistec.com/images/M156SC30a.jpg Weistec Stage 1 Supercharger System The Weistec M156 Stage 1 Supercharger System is designed for a completely stock 63 AMG. Easy installation, with 637 horsepower, and 560 ft-lb torque makes this a perfect package for those not looking to compromise their car with loud exhaust, yet make great power. Priced at $12,999.99. Key Features: 2.3L Twin-Screw Compressor Module 1000hp Liquid to Air Intercooler Core High Flow Cast Aluminum T6 Hardened Lower Manifold High Flow Cast Aluminum T6 Hardened Throttle Body Inlet Y 45mm Boost Bypass Assembly Billet Aluminum Direct Drive Cradle System Supercharger Serpentine Drive Belt Hard Anodized Billet Aluminum Serpentine Idlers Johnson CM30 30 Liter/Min Intercooler Water Pump Intercooler Water Recovery Tank Cross Flow Heat Exchanger High Flow Fuel Rail System Molded Silicone Couplers Power-Steering Reservoir Relocation Assembly Weistec Engineering Stage 1 Supercharger System ECU Reflash Dyno graph below. http://weistec.com/images/m156scs1.jpg Weistec Stage 2 Supercharger System The all new Weistec Stage 2 Supercharger System is designed for those who have already installed high flow exhaust and air filters. Supercharger drive ratios have been properly adjusted to equalize boost with the higher flow exhaust. Priced at $12,999.99. Key Features: 2.3L Twin-Screw Compressor Module 1000hp Liquid to Air Intercooler Core High Flow Cast Aluminum T6 Hardened Lower Manifold High Flow Cast Aluminum T6 Hardened Throttle Body Inlet Y 45mm Boost Bypass Assembly Billet Aluminum Direct Drive Cradle System Supercharger Serpentine Drive Belt Hard Anodized Billet Aluminum Serpentine Idlers Johnson CM30 30 Liter/Min Intercooler Water Pump Intercooler Water Recovery Tank Cross Flow Heat Exchanger High Flow Fuel Rail System Molded Silicone Couplers Power-Steering Reservoir Relocation Assembly Weistec Engineering Stage 2 Supercharger System ECU Reflash 672 Horsepower, and 662 ft-lb Torque. Dyno graph below. http://weistec.com/images/m156scs2.jpg Weistec 6 Rib Direct Drive Belt System. (Shared between the Stage 1 and Stage 2 systems.) http://weistec.com/images/m156s1s2sc1.jpg Weistec Stage 3 Supercharger System The Weistec Stage 3 Supercharger System is what people said could never be done! Utilizing our all new 3.0L Twin-Screw compressor, this system makes 769 Horsepower, and 677 ft-lb Torque and is capable of creating in excess of 1000 Horsepower with our engine internals, and transmission upgrade. Check out how our complete build breaks the world record at 144MPH in the quarter mile! Priced at $15,780.99 Key Features: 3.0L Twin-Screw Compressor Module 1000hp Liquid to Air Intercooler Core High Flow Cast Aluminum T6 Hardened Lower Manifold High Flow Cast Aluminum T6 Hardened Throttle Body Inlet Y 45mm Boost Bypass Assembly 8-Rib Direct Drive Belt System SFI Approved Light Weight 8-Rib Crank Damper Crank Pin Drill Tool Billet Aluminum Direct Drive Cradle System Hard Anodized Billet Aluminum Serpentine Idlers Johnson CM30 30 Liter/Min Intercooler Water Pump Intercooler Water Recovery Tank Cross Flow Heat Exchanger High Flow Fuel Rail System High Capacity Fuel Injectors Molded Silicone Couplers Power-Steering Reservoir Relocation Assembly Weistec Engineering Stage 3 Supercharger System ECU Reflash Dyno graph below. http://weistec.com/images/m156scs3.jpg The new 3.0L Twin-Screw Supercharger System. http://weistec.com/images/m156s3sc1.jpg Stage 3 8-rib belt drive system. http://weistec.com/images/m1568rib.jpg Please let us know how we can assist! Thank you all! Weistec Engineering |
Prices are looking much more attractive...
What about a SC kit for the NA 5.4 AMG engine?
Any shops in Europe ?
now build a supercharger for the m157
best of all the worlds then |
Originally Posted by Klinh
(Post 5367781)
i love the new pricing....very very attractive
So we are talking close to $20,000.00 with the installation?
CARB approved...congrats, that is phenomenal.
Any compressor maps or info on the blowers? Are they PD or twin screw, how many lobes on the rotors, what kind of twist, who's guts are in the blower, etc?
Weistec are simply the Best. Many of us are thankful that we have their hard work applied for our engines. Excellent press and excellent write up. Prices are very fair and products are second to none.
Can wait to get the treatment:naughty: |
Originally Posted by Aleksandre
(Post 5367788)
Originally Posted by bhamg
(Post 5367881)
Originally Posted by ArthurJGuy
(Post 5367920)
If you have a tune and you buy the supercharger, will the tune become useless or do they somehow work hand in hand with each other? In other words, do they affect each other in any way?
Originally Posted by Weistec
(Post 5368001)
A PD is a twin-screw. It is actually both a roots and twin-screw. We use a twin-screw design due to many reasons. One being the RPM and flow of the engine being much higher than any other V-8. Visit our website for more information on our compressors. Thank you!
A roots compresses air one time into the engine, a twin screw compresses air twice, once in the head unit and then a second time in the engine. An Eaton/TVS is a roots while a Whipple/Kenne Bell is a twin screw. Your blowers look like Whipple cases and are even the same displacement as Whipple products. I do not see any compressor maps or rotor info on your website about these head units specifically, in fact the only chart is the dyno posted above. |
Just placed my order for a stage 3 weeeoooo.
Now I just need a car to put it on hmm |
Originally Posted by Merc63
(Post 5368441)
Now I just need a car to put it on hmm at least now you know which horse you have to get! :naughty: |
all smiles... Merry Christmas to me!
ive added the (recommended upgrades) up and alone they cost around 20k .. how recommended are they? meaning the car will break down without them ? cause it seems to me a truly useful package would set me back 40-50k plus install ??
Originally Posted by c63edition1
(Post 5368787)
What stage are you referring to? |
That's a whole lot of power boys! Very glad to be one of their East Coast dealers.
Originally Posted by dremorg
(Post 5368033)
(Post 5368787)
The CARB system is designed for a completely stock vehicle. It is bolt on and go. This is the same with our Stage 1 System. It is also a bolt on and go for completely stock vehicles that don't mind emissions standards. The Stage 2 is designed for vehicles that already have high flow exhaust. If you already have headers for example, this is bolt on and go system. Our Stage 3 system is the only system which we recommend our transmission upgrade, and it is mandatory to run our spark plugs. In other words, for $12,999 plus right around $2,500 for a professional installation, you can have a supercharged C63 that is making 520-550 HP at the wheels. Our Oil/Air Separator System is recommended for all 63 AMG's even if they don't have our supercharger system. You will be doing your engine a favor by installing it because it will save it from detonation, and serious oil grime on the valves and pistons surfaces. Let us know how we can assist and thank you for your interest! Weistec Engineering |
brought the car to work today and had a chance to jump on the gas and all i can say is :eek::eek::eek::eek::eek:
this car is scary fast :y the guys at Weistec build some real monsters so if you are interested in upgrading , i would suggest giving them a call . you will not be disappointed :bow: the wait was well worth it |
Originally Posted by BAD430BENZ
(Post 5371317)
this car is scary fast :y the guys at Weistec build some real monsters so if you are interested in upgrading , i would suggest giving them a call . you will not be disappointed :bow: the wait was well worth it What exactly did you have done? |
(Post 5371369)
(Post 5371284)
Weistec Engineering Very nice. :y |
