C63 AMG (W204) 2008 - 2015
Side bolster wear and tear
Old Nov 25, 2012 | 11:23 PM
tdotjag's Avatar
2012 C63 w/APX
So I've had my 2012 for about 4 months (daily driver) and the drivers side left bolster looks like I've had my car for about 2 years. What do you guys use to treat your leather? I really want to maintain the matte look, so pls don't suggest anything that would leave a shiny finish.
Old Nov 26, 2012 | 02:41 AM
Gremlin9's Avatar
Porsche 911
Just switch the sides, from passenger seat to drivers seat and it will last twice as long.
Old Nov 26, 2012 | 03:21 AM
JimmyR's Avatar
E63S
I have a 2010 model with the same issue. It is very common I believe. Like you I noticed it fairly early on - definitely less than a year old. Not helped by the large side bolsters getting in the way when you get in/out of the seat, plus I think the lap sash part of the seat belt rubbing over the bolster when you first put it on. I have been careful since then how I get in and out of the seat - use that Easy Entry setting or whatever it is that lifts the steering column up - and try to keep the lap sash under the bolster as you do up the seat belt.
If it helps in the almost 2 years since I first noticed it not sure it has got any worse by being careful as above and using leather care stuff fairly regularly.
I mentioned it at first service - got the old we will have a look sir - and then "normal wear and tear, if it gets any worse we will have another look"
Old Nov 26, 2012 | 03:24 AM
Chargin55's Avatar
2003-E55 2011-C63 2016-C63S
I had the same problem with a bolster on a 500SL which was scuffed by a waist belt. I had the bolster rubbed back and repainted and it looked like new again. I asked the guy who did the work the same question about cleaning leather and was told the only way to do it properly was with a slightly damp cloth. If requiring stain removal use lightly soaped water. I have used expensive leather cleaners in the past and like you suggest the leather took on a shine, so I now wipe my seats over with a wrung out chamois which works very well.
I find the leather in the C63 is a lot softer than my prior owned Mercedes’. My C63 has only done low miles and signs of wear are already evident. When the leather is shot to hell I will get a good upholster to replace it like new again. At the end of the day it’s not an expensive exercise.
Old Nov 26, 2012 | 03:43 AM
xxGenericSNxx's Avatar
99 ML430, 01 CLK55, 07 R63, 15 E63 Wagon
For you guys experiencing fast wear, might I ask if you have the premium Nappa Leather or the standard leather?
Old Nov 26, 2012 | 09:57 AM
tdotjag's Avatar
2012 C63 w/APX
I have the nappa
Old Nov 26, 2012 | 12:28 PM
b16's Avatar
b16
2009 C63, 2000 ML 430, 1994 Del Sol Vtec
Had mine repaired by the dealer under warranty. They basically just restain and recondition it. Looked great afterwards!
Old Nov 26, 2012 | 03:01 PM
HoozyerdaddyC63's Avatar
C63
Seriously? I would have never thought that would be something covered under warranty. What did you say to them to get it done?
Old Nov 26, 2012 | 03:52 PM
Pickles's Avatar
(a)'12 C63 P/P, LSD, 19" m/spoke,comfort pack. (b)Astra SRI.
Thumbs up
Wear on seat bolsters is a problem with many cars.
Careful entry & exit can do a lot to diminish the issue...by that I mean that I do not let any of my body touch the bolsters getting in & out.
Some people just don't give a stuff though....they'll actually SIT on the bolsters, really RUB them getting in & out etc etc.....a bit of extra care will go a long way.
Cheers, Pickles.
Old Nov 26, 2012 | 05:02 PM
cptdaz's Avatar
home the point
My fat *** always rub the booster when I get into the car, so yeah, that area is more wore down than the rest of the seat.
Old Nov 26, 2012 | 07:59 PM
Chargin55's Avatar
The easy entry steering wheel function only moves the wheel up about an inch in my C63. Can this be programmed to move more? In my E55 it was more like 2 to 3 inches and this makes entry a lot easier.
Old Nov 26, 2012 | 10:00 PM
EkS's Avatar
EkS
C63
Are you guys programming one of your memory buttons for an easy exit?! If not, I suggest you do!
Old Nov 26, 2012 | 10:27 PM
C63
That's a good idea. Never thought of that.
Old Nov 27, 2012 | 12:51 AM
JimmyR's Avatar
E63S
Pretty sure it is the Nappa leather
Old Nov 27, 2012 | 01:09 AM
CaliTheKid's Avatar
2013 C63, 2009 SL550
If you wear a cell phone on your belt that will rub it as well.
Old Nov 27, 2012 | 01:15 AM
b16's Avatar
b16
I told them I thought the wear was excessive. The dealer has a 3rd party they use for leather work and had him quote the job at ~$150. The SA brought out the service manager, explained the situation and the service manager decided to cover it. Great guys here at Walnut Creek MB!
Old Nov 27, 2012 | 01:28 AM
CoolBDPhenom03's Avatar
Vivid Racing '09 C63 AMG
Do you have before and after pics? That's where I take my car too!
Old Nov 27, 2012 | 02:03 AM
You seem to have confirmed my suspicions, tdogjag and JimmyR. Nappa leather, by nature, is a much more thin and fine grained leather than the standard kind used in the C63. I've got it on my 01 CLK55 and the 07 R63 and they do have some signs of wear but I don't think it's too bad (50,000 miles on each). Some areas are shiny on my CLK from the most touched areas (butt of driver's chair) and there's some small creases on my R's side bolster on the driver's side butt and seat back. I try to minimize the issues with leather care but it seems inevitable with this leather. I personally find the tradeoff worth it for having a very soft leather and it's very nice to touch. More leather conditioner?
Old Nov 27, 2012 | 10:26 PM
b16's Avatar
b16
I can take after pics, I have no before pics. Imagine typical bolster wear at 50,000 miles?
Old Nov 27, 2012 | 10:38 PM
I'm almost there! Who did you work with? I usually go to Walter.
