C63 AMG (W204) 2008 - 2015
C63 with E63 wheels
Old Dec 2, 2012 | 02:00 PM
topcoder's Avatar
2018 E63S
C63 with E63 wheels
Hey all - I put a set of E63 type wheels on my C63. While thinking about this, I wasn't able to find any decent pictures of this, so I thought I'd share.
Old Dec 2, 2012 | 02:06 PM
Even Money's Avatar
'15 VW GTI
Does it rub? Looks good....you'll have to come out to the track with us in the spring...
Old Dec 2, 2012 | 02:24 PM
MIG's Avatar
MIG
C63AMG PP
Look perfect
ET ?
Tires size?
Old Dec 2, 2012 | 02:27 PM
topcoder's Avatar
2018 E63S
Thanks, I'd love to get it out to the track. Somehow through an M5, a 911, 2 M3s, a C32, and a 335 I never managed to get on it. This spring, that will change!
I haven't noticed any rubbing, though lowering it is probably not an option any longer.
Old Dec 2, 2012 | 03:20 PM
topcoder's Avatar
2018 E63S
Originally Posted by MIG
Look perfect
ET ?
Tires size?
The wheels are 8.5x19, 9.5x19, both 45mm offset.
The fronts have a 5mm spacer so that the wheels clear the calipers. Longer, non-standard lug bolts are required. Finding these are like trying to find pink unicorns, but I managed to locate 28mm shank lug bolts that worked at ezaccessory.com.
The tires are 245/35-19 in front and 275/30-19 in back.
Old Dec 2, 2012 | 03:50 PM
Karl901's Avatar
Porsche 911 Turbo S 2014! E63S 14, Audi S8 13, CLS63 12, E550 12, C63 09, all tuned
So the rims are E63 but the tire sizes are smaller, correct?
Old Dec 2, 2012 | 04:18 PM
AMGFANs's Avatar
12 MB C63
I believe is E63 style rims for the C63 since the E63 rim's bolt pattern is different than C63..
sharknodi's Avatar
Hope it's not rubbing, but looks awesome.
Old Dec 2, 2012 | 05:01 PM
topcoder's Avatar
2018 E63S
They are actually replicas, I'm not sure what the actual E63 set up is. I picked the closest offset to the c63 oem wheels (45/54). The tires are the closest to the stock overall diameter while taking advantage of the width. They are probably smaller overall diameter than the E63 tires.
Old Dec 2, 2012 | 05:02 PM
topcoder's Avatar
2018 E63S
So far so good, thanks!
Old Dec 2, 2012 | 05:21 PM
ProjectCamaro's Avatar
Pewter W211
Looks perfect, thank you for posting the pictures.
Old Dec 2, 2012 | 05:28 PM
Crazy4Cars's Avatar
W212 E350 AMG E63 Pack.
E63 wheels offset is different, not the bolt pattern.
Old Dec 2, 2012 | 05:30 PM
AMGFANs's Avatar
12 MB C63
ops..thanks for correcting me!
anyone know if 48mm would be good for the rear?
Old Dec 2, 2012 | 05:38 PM
Roswell's Avatar
2010 C63 AMG, 2009 ISF , 2002 L-Tuned IS300, 2011 ML350
Looking great!
19x9.5 + 45mm with 275/30 must rubs over bumps or with rear passengers.
Old Dec 2, 2012 | 07:37 PM
Mort's Avatar
The wheels look great.
I agree with Roswell on the possibility of the rears rubbing over high speed bumps and with rear passengers.
The stock lug bolts on our cars are Ball Seat M14 x 1.5 with a 27mm shank. I don't think the 28mm lugs are long enough with 5mm spacers provided your reps take the same length bolt as stock. You should probably get 32-35mm shank lug bolts. They can be a little longer on the front because there are no emergency brake components to hit in the front hub.
You can get lug bolts at RAD USA Direct http://www.radusadirect.com/category...l_seat.m14x15/
Old Dec 2, 2012 | 09:53 PM
Roswell's Avatar
Yes listen to Mort & get 32mm lugs bolt for ur safety. Our oem lugs are 27mm + 5mm spacers = 32mm .
Mort, thx for the link to the extended lugs.. Awesome link with all the length, it should be in the sticky on top as few members had problem finding 32mm.
Old Dec 2, 2012 | 11:47 PM
Capn's Avatar
03' CL600
Looks similar to mine
Old Dec 3, 2012 | 01:14 AM
Rony Kingmillo's Avatar
I am using 51mm for the rear. Looks awesome
Old Dec 4, 2012 | 05:34 PM
LuisC55AMG's Avatar
C63, C55 (Sold)
Looks good. How is the ride? Did it change a lot or not?
Old Dec 4, 2012 | 07:05 PM
Looks awesome. I love it. A bit of a rub but easily fixed on the inside rug part.
Old Nov 24, 2013 | 01:24 PM
fars's Avatar
c300
Those are very nice replicas with amg engraving where did you get them from what website? company?
I would love to get a set myself.
