C63 AMG (W204) 2008 - 2015
Need Help! Water in headlamps!
Old Jun 20, 2013 | 05:40 PM
w204nyc's Avatar
2017 C63S coupe '09 C63, '15 Durango RT, '14 Jeep SRT8
I've been having an issue with my headlights for quite some time now. I have stock bulbs in with AZN LED Eyelids. For the last two months, my headlights have been going off. I've tried changing the bulbs and they still don't go on. Usually after about 20min of driving they go on. They have been doing this at least once every month. I took the car to the dealership a couple of times and they haveb not found anything wrong. Last week both bulbs went off and never came back on. I tried swapping out the bulbs and had no luck.
I had the car at the dealers and just picked it up today. They told me that there was water inside my headlights caused by the LED Eyelids that were used.
This is what the paper reads: Performed SDS Short Test, found codes for open circuit on left and right side headlamps. Checked values using SDS Test, control module not reading. Checked Headlamps and found water moisture inside and after market bulbs installed with pieces of LED bulb that were installed. Found water damage to headlamp and control unit.
Total Cost $3,800.
My question is how can I get them to prove that the LED's are to blame for this. I know they are just using the oldest trick in the book and blaming it on the first thing they can. What are my options here? Any help would be appreciated.
Old Jun 20, 2013 | 07:06 PM
shades's Avatar
09 C63, 11 Cayenne S
I dont see how water got into the eyelids in the first place, they have caps that go over the bulbs. Unless there is a crack in the actual eyelid lense itself. They are pulling a fast one on you because of the AZN lights. Make them prove that the actual aftermarket bulbs caused the water damge to your headlights...or if they are saying that the AZN's caused a short somewhere, then i think your SOL
Old Jun 20, 2013 | 07:47 PM
w204nyc's Avatar
They are saying water came through the eyelids. Makes no sense to me neither because all four of them had caps. Warranty said they wont cover it and I dont really know what to say to them.
Old Jun 20, 2013 | 08:09 PM
CoolBDPhenom03's Avatar
Vivid Racing '09 C63 AMG
That's bs. I've replaced mine with the same LEDs. The only way that could be feasible is if you didn't close up the holes for the eyebrow bulbs and water got in. But that means water would have to get under the hood, then reverse direction to go forward into the headlight assembly.
Old Jun 20, 2013 | 09:38 PM
w204nyc's Avatar
I know its BS but I cant prove anything. Not sure what to do or who to speak to. The only thing I can think of is to put the stock eyelid bulbs back in and take the car to another dealership and hope they fall for it
Old Jun 20, 2013 | 11:58 PM
You shouldn't have to, but try that and stay away from the other dealer. Utter BS.
Old Jun 21, 2013 | 03:49 AM
Harold1898's Avatar
2015 E400 Coupe
Hmmm, well first off you have the base question, Was there water in the headlamps? Secondly, who says how it got there? What is their qualification that supports their assessment decision? Now here is the tricky point, can this be validated or denied by a third party? Some questions, did you authorize the repair? Did you willingly pay for the repair? Did you record your concern and ask for validation at the time of purchase (payment)?. Does the evidence still exist?
What you should do depends on the answers to these simple questions.
Good luck mate, I have a feeling you just may need it.
Remember, a point in law is a lot different to a point in principle.
Old Jun 21, 2013 | 03:52 AM
Harold1898's Avatar
2015 E400 Coupe
Having reread the post, I am not sure you had the repair done, if not then it is a whole different ball game.
Old Jun 21, 2013 | 10:11 AM
w204nyc's Avatar
No I didnt have the repair done. I spoke to the foreman and he is the one saying that water got through the LEDs but cant really explain how its possible. I asked him to pop the hood and explain how it got in and he couldnt even do that.
Old Jun 21, 2013 | 10:47 AM
Man, if he can't explain it, he has no right to try to stick it to you. If you want to continue to work with that dealer, I'd talk to the general manager and call bull. Otherwise, go somewhere else with the stock bulbs, like you said.
Old Jun 21, 2013 | 11:54 AM
w204nyc's Avatar
Thats the best I can do. Ive been buying cars from yhere for seven years, I didnt expect them to be such *******s
Old Jun 21, 2013 | 11:57 AM
Guilty's Avatar
'16 C63-S
Which dealer?
Old Jun 21, 2013 | 01:21 PM
I am Jeff's Avatar
Steel Grey Metallic C63!!
If that's what is stated on your repair, you should make sure to argue that shyt till it's rectified. That comment is now attached to your car's vin#. Your headlamp warranty is now voided until you get it fixed through them.
Old Jun 21, 2013 | 03:38 PM
w204nyc's Avatar
Originally Posted by - Guilty -
Which dealer?
Mercedes of manhattan
Old Jun 21, 2013 | 03:39 PM
w204nyc's Avatar
Yea thats what one of the dealers told me. He said I can try but most likely it will be in the history
Old Jun 21, 2013 | 03:49 PM
Guilty's Avatar
'16 C63-S
Worst dealer ever, that place is such a scam.
Talk to Robert, that guy is easy to bribe. I tipped $300 to have my handle fixed the same day because he wanted to keep the car for the week end... money talks bs walks... I'm sure if you give him a little donation he'll have it fixed for free. It's the sad truth. But MB of manhattan is the worst dealer EVER, it's owned by MBUSA, all they want is your money. Hate it there.
Old Jun 21, 2013 | 03:51 PM
I am Jeff's Avatar
You just put that guy on blast for everyone at corporate to see. It's not exactly hard to figure out who "Robert" is, if that's his name.
Old Jun 21, 2013 | 03:53 PM
w204nyc's Avatar
Can't be mad at him for that though. The majority of them are shady. Even my SA blamed the LED eyelids as soon as he saw them. So even he is looking to **** me over. Are there any laws or rules on aftermarket parts regarding warranty?
Old Jun 21, 2013 | 03:56 PM
Guilty's Avatar
'16 C63-S
I don't care I'm not going back there ever. I didn't give him $300 because I wanted to, it was because I had no choice. He said they were super busy bla bla bla, no loaner available and kept talking shït... when I offered him money car was fixed in the next hour.
I'll go to the dealer in Brooklyn or Queens if I ever need to go to the dealer.
Old Jun 21, 2013 | 03:58 PM
w204nyc's Avatar
I just got extended warranty from them. Arent they supposed to inspect my car before giving me the warranty. I had a tune before I got the extended warranty so what will happen now if something would go wrong with my engine?
Old Jun 21, 2013 | 05:02 PM
They're just d-bags if they deny a warranty claim because of a tune. It shouldn't matter. The PP, 507, and BS engines are basically tuned versions of ours.
Old Jun 21, 2013 | 10:07 PM
w204nyc's Avatar
Do you think installing regular headlamps without the bixenon packge would be a smarter thing to do. There is a company called lightwerkz that do great retrofits and with all said and done it will be cheaper than bixenons.
Old Jun 21, 2013 | 10:32 PM
Heck no. The xenons are awesome.
Old Jun 22, 2013 | 10:56 AM
Mort's Avatar
I don't see how they can blame water damage inside the headlight unit on the LEDs. The LEDs are in the stock sockets and the covers are on the outside of the housing. The LEDs are essentially just replacement bulbs. It is not clear what fault they are blaming on the LEDs from your post. Maybe they are saying the covers were not replaced correctly when the LEDs were installed. I don't think they can blame the LEDs directly for the water damage. Can you determine how the water got into the headlight units? If it is a fault of the headlight casing itself maybe you can get warranty coverage. Ask them specifically how the LEDs are at fault for causing the damage to the headlights. I don't think the LEDs themselves can be directly blamed for water damage inside the headlight.
Old Jun 22, 2013 | 12:27 PM
w204nyc's Avatar
I will. I took my car back because they refused to do the work under warranty so I figured I might as well take it back until i have enough info to dispute this. Ican still drive just not at night. Ive also had the car there 3 times in the last 4 months because the headlight kept going on and off and they never found a problem.
