Transmission Fluid Pan Art #
2009 Iridium Silver C63
Getting ready for a DYI trans. fluid change. Anybody know the part number of the re-designed fluid pan and fill tube we're supposed to use? Is there a special fill adapter required or will standard fluid pump suffice?
Shell 134 is the ATF fluid.
You need a filter, gasket, filler straw and bolts for the pan.
A pump with the threads of the tranny drain bolt to pump fluid back in.
hi, the new oil pan (as of june 2010) has oval depressions under, also you should use the green colored overflow pipe with it. The old one has a chamfered edge, used with white overflow pipe.
