C63 seat lumbar support problem
Hi there, new member here with a C63!
I have noticed that the 3 buttons on the inner of either seat which control lumbar support and the side bolsters is not working on either seat.
I have replaced a blown 5amp fuse labelled as "neck-pro" and upon pressing the buttons nothing happens, but shortly after the fuse is blown again.
I have been told on the UK forums this sounds like a short in the seat, has anyone else experienced this issue and know where to start?
Ah, doesn't sound too promising, bearing in mind my car is out of warranty now!
A couple of members on the other forum only had their car in for a day or two, and was told 'a wire had chafed in the seat and was shorting, we replaced said wire' so wondered if anyone had experienced the same and could tell me which wire...hopefully!
I have a 2010 and I have the same problem. I change the fuse like 5 time and still get the same problem. November 13 they took my car for the day they will check a-z to see what's going bad on this
Okay one question did you replace the fuse box(Sam unit) located in the rear of your car ? Mine blew up and mercedes replaced it and after that my seats didn't work, my dealer told me the seat needed modification they did that but that ended up blowing the fuses so it really didn't work. They ended up ordering a new electrical unit for the seat. I hope yours is not similar because if it is my dealer had quoted me around 2k for this fix !!! Luckily I still have a warranty so they covered it.
