Is it possible ECU tune will be found by dealer when diagnosing transmission?
#51
Most tunes do not write over the counter, its not like Audi and others. It leaves the rest whole.
As per your statement about it wearing out the engine quicker, 100% agree. Same goes if you drive your car hard or not. Engine will last longer if you drive it like a grandma.
If you drive one of these cars like a grandma it will become a lemon plain and simple
#52
Speaking of garbage, you can't tell me that u think the engine will last longer by bouncing off the Rev limiter all the time. Point was if u hammer it all the time the engine will not last as long if u didn't. It's called internal stress.
#54
No body knows how long these engines last
But why buy a amg for to drive like a *****
These engines are high performance engines they were built for one reason
You should of brought a c180 or c250 if you wanted to drive slow
#55
Wow, do u read the other posts at all? Someone else said the tune is going to shorten the life span, and my point was driving it easy will help it's life to. But this isn't what the car is made for so please read.
#57
when you find an engine failure from an internal component from driving it too hard and not outside influence let me know.
#58
#59
And driving slow clogs everything and you gain carbon build up and so on
#60
And Thor just letting you know road has a supercharged c63 with 15000miles or so and his had no issues
I'm sure your not going to keep your car till 200000kms
#61
W204 C63 Coupe, W166 ML350 BlueTEC, 928GT, C5 Z06 & IS300 race cars, EQE 4Matic+ on order
I said the tune is going to shorten the engine life span, but I agree with roadtalontsi that driving the engine "hard" (assuming it has properly warmed up and has the proper oil) is not going to shorten the life span and in fact the opposite may be true.
If you drive your car like a grandmother, you're more prone to get carbon buildup as a result. The carbon acts like a thermal insulator and you create hotspots in the combustion chamber, which in turn can cause detonation and pre-ignition. Regularly revving the engine through the entire RPM range on the other hand helps in preventing carbon buildup, so it that sense a properly exercised motor is less likely to suffer from carbon buildup than one that rarely revs past 2500 rpm. Furthermore, all other things being equal, detonation occurs more readily at lower RPMs because of the slower burn rate (longer burn time) of the mixture, and increasing the engine RPMs under the same conditions would eliminate detonation. So yeah, driving like a grandma is going to be worse for the car than driving it like you stole it.
The problem with tunes is that the vast majority of them simply alter the ignition timing and the AFR (varying the throttle response BTW does nothing for increasing actual engine power, only how much power is being delivered at a particular position of the pedal). By trying to get that extra 10 hp out of the motor, you either have to lean the mixture or advance the timing, and with the garbage that sometimes passes for gas these days, you really are taking a chance even with just a "91 octane" tune. You may be getting mild detonation in only one cylinder for example, which even the knock sensors may not be able to always pick up and the engine can go on for thousands of kilometers before you realize that you've had excessive particle wear for a long time and that the internal engine bits are worn.
It's all chemistry and physics and there is no magic formula. As I've said before, I've tuned my own 928s, built, blown up and rebuilt motors (not all by myself of course but under the guidance of a race engine builder that knows a lot more about them than I do) and I have yet to see how a tune on its own for a properly designed and optimized motor - and MB/AMG is certainly among the top in terms of their knowledge and R&D investment - can give you anything without sacrificing something else like the small margin of error (allowing for crappy gas for example) or reliability.
#62
#64
bearings - no they should never wear out they are hydrualic - the only way these are damaged is by oiling issues. be it starvation or contamination. rings and cylinder walls - these are going to wear out over time sure, but with the newer nano technology anti friction coatings and preparation put on the cylinder walls you can still clearly see cross hatching and little to no distortion at 100k miles in the block. these motors are stout. Keys to survival are - regular oil changes/maint. use good premium gas not cheap costco/kroger crap that saves you 3cents a gallon. make sure the car is warmed up before you go ******* on it. Avoid little 2 minute drives as the car never gets up to operating temp - this is where you get carbon/fouling problems. This why its good to go give it hell every so often and clear it out. If you modify it spend the money to get it done right. Trust me the rest of the car will fall apart long before the engine. Ive driven blown e55's poorly maintained with 150k+ that run better than ones with 20k because they are grandma'd to church and the grocery store once a week.
im at 26k now, around 15k of it with the blower.
#65
2015 E63S AMG & 2013 GLK350
I do agree with dealing with problems a tune may have created, I am however always concerned that the dealer would try to deny a claim based on the tune regardless of the tune having caused the problem or not. When my car was bone stock and under 3k miles the driveshaft twisted and snapped at the hanger bearing, the first things they asked was about a tune and abuse and that's what bothers me because looking to get out of their responsibility seemed to be the first concern.
#66
2022 EQS 450+ until my 580 comes in
Transmission on my 2011 is acting up, have to have it checked but want to check with the community first and see if anyone has had their ECU tune found by the dealer during warranteed work that could involve ECU, like the tranny?
Help guys!! I dont want my warranty voided!![EEK!](https://mbworld.org/forums/images/smilies/eek.gif)
#67
![rolf](https://mbworld.org/forums/images/smilies/rofl.gif)
#68
I did mine through my dealer from Renntech, they charged me 250 for label, and said it would not influence my warranty.
They told me Renn is kind of certificated by MB, I don't know if it's true.
#69
![smash](https://mbworld.org/forums/images/smilies/smashfreak.gif)
#72
not true at all, no aftermarket modifications are "certified by mb". It's not like bmw and dinan. because AMG is the dinan to mercedes. the factory warranty will cover everything unless it's from a consequence/failure from the tune, like a melted piston etc... chances are very unlikely as renntech are kind of softies and very conservative.
#73
#75
Misinformation here. AMG/Dinan 2 totally separate concepts.
Renntech can be warrantied, it's just not by MB itself, it's by the actual dealer who chooses to install and warranty aftermarket items from brand x, in this case Renntech. Most dealers opt not to do this because they need to have folks on staff who are trained to install and service these modifications, and they also are inviting further costs down the line. Usually not a profitable venture so most stay away.
It's totally plausible to have a "warrantied" Renntech car, it's just not by MB, it's by your dealer. Any standard items (window switch, AC stops working etc) would be covered by any dealer, but if you took your car to another dealer with a check engine light, they say the tune is the cause, they can deny the claim and send you back to the dealer who installed it.
