C63 AMG (W204) 2008 - 2015
"Oil" Leak, Rear Right Tire...thoughts?
Old Nov 12, 2013 | 10:22 PM
JDubya3's Avatar
2009 C63
Noticed a spot in my garage on Monday morning...Oily dark substance near the rear right tire. Had a look under the car...surely something is leaking....the spot was there again this morning. Going to get it checked tomorrow...any thoughts?
-Brake line?
-Axle boot?
Old Nov 13, 2013 | 02:50 AM
m a x i m u s's Avatar
C63 AMG P30 *EuroCharged*| Porsche Cayenne | Buell XB9SX
if it's thin oil, I'd say brake line.
Old Nov 13, 2013 | 08:11 AM
Mort's Avatar
Check your brake fluid level.
Differential?
Old Nov 13, 2013 | 11:17 AM
otakki's Avatar
FF. W212 E63 M156 non-pano 18" P2 ParkT NightV (gone but will be missed).
It could also be from the shock. Such a leak from a shock happened to me 4 years ago on the rear right of one of my cars.
Old Nov 13, 2013 | 11:40 AM
ddcha's Avatar
2022 E53 SG
Differential leak is my guess.
Old Nov 13, 2013 | 12:26 PM
Ezec63's Avatar
C63 Coupe
If you have an LSD If say your seal is busted and a diff leak on that side.
Old Nov 13, 2013 | 12:39 PM
Merc63's Avatar
C63 AMG
Diff oil will be thick and smell bad. Anything else will be thin. Crawl under there you should see where it's coming from as it will look wet.
Old Nov 13, 2013 | 12:47 PM
Ezec63's Avatar
C63 Coupe
Yes diff oil has a distinct smell. When mine was leaking it also was dripping onto the exhaust so the smell of burnt diff oil is very noticeable.
Old Nov 13, 2013 | 06:21 PM
abcut973's Avatar
'12 C63 Black Series, '12 ML350 BlueTech
Jack your car up and check for oil on your differential.
Just happened to me as my diff is leaking but unlike you i don't have any spots on the floor. Just the diff being covered with oil.
If not check your brake lines. GL
Old Nov 13, 2013 | 06:26 PM
Ezec63's Avatar
C63 Coupe
Yupp mine wasnt really "dripping" either it was "weeping" or oozing out of the driver side diff seal. This over time caused it to accumulate and get onto the exhaust that would than burn it off when hot and it smelt weird. New seal fixed it right up
Old Aug 11, 2014 | 08:44 PM
MTV10's Avatar
E55 AMG & C63 AMG
Bumping an old thread..
Ever find the issue? Noticed a nice oil spot in the garage today, right by rear right tire.
Just had the brakes done so I'm guessing brake line got pinched somewhere along the line...
Old Aug 18, 2014 | 08:28 PM
JDubya3's Avatar
2009 C63
Busted right rear shock!
Old Jun 26, 2020 | 05:19 AM
eashwar63's Avatar
C63 AMG SEDAN 2013 (PP)
I am facing the same problem with my Car's rear right shock now.... What is the solution sir? My car is 5 years old, but has done only 19k Kms.
Old Jun 26, 2020 | 08:23 AM
roadkillrob's Avatar
Top Answer: 1
12 C63BS Magno Alanite Grey, 25 X5 Msport, 08 BMW E93, Ducati Hyper 698
Low miles is almost as bad as high miles some times, so just sitting for long periods of time, seals dry out and can cause a shock to leak as much as putting 150k on it, could also just be defective and was destined to leak early, but fix it is get a new one!
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
If your shock is leaking oil, replacement is your only option.
Old Jun 29, 2020 | 10:56 AM
eashwar63's Avatar
Merc showroom in India, Bangalore quoted 650$(incl labor) to replace the failed shock....will the other shocks also fail overtime? Or Is it better to change the entire set with aftermarket ones like KW or bilstein?
Old Jul 2, 2020 | 04:23 AM
DRBC43AMG's Avatar
From: CH = Land of mountains, cheese, chocolate and watches
Personally I would not change just one shock, not unless the vehicle has very low mileage. The minimum could be a change in pairs, or for less potential problems change all four.
