C63 AMG (W204) 2008 - 2015
Weistec goes 9.75 @ 152MPH resetting world records
Old Nov 20, 2013 | 10:58 PM
jrcart's Avatar
2008 CLK63 Black Series 2012 C63 Black Series 2014 SLS Black Series
Red face
Originally Posted by vdubpower
actually, jim, do u mind commissioning it for me...your $$$ works better than mine...lol
Damn, you should have hit me up this morning, I already hit my daily limit, picked up a new 2014 F350 today.
Old Nov 20, 2013 | 11:22 PM
roadtalontsi's Avatar
10 C six trizzle
Ya definately looks like it has problems coming of the line. Maybe try to lift the back end up even higher to fit some taller tires on it. We have to do that on supra's all the time to stuff some 28" tall tires on there. Also helps to have boost by gear, which obviously you cant use with a blower. Maybe toss some nitrous on it in the top end, get you another 10mph and .2 seconds. - ya not really worth it just though id throw it out there. Always awesome to see your cars handle business.
Old Nov 21, 2013 | 12:08 AM
vdubpower's Avatar
i drive them all, fast and hard
4 matic conversion?
Old Nov 21, 2013 | 07:34 AM
mthis's Avatar
Anything W/4Wheels
Congrats guys That's hauling,
Nice meeting you guys and see you soon.
Old Nov 21, 2013 | 08:43 AM
mdgrwl's Avatar
C63 AMG
You guys should be able to get LOW 9's if you can get a better launch. 1.6x 60ft isn't so hot with that amount of power.
With that amount of power, you should be able to get 1.4x 60fts, which would get you down to mid to low 9's.
To do so you, that means completely turning the car into a dedicated drag car with 15" conversion, built axles, built drive shaft, softer rear springs and drag race dampers. I'm not sure if that car uses a TC, but if so, a high stall (4000+ TC) would be needed to....
Old Nov 21, 2013 | 09:32 AM
jrcart's Avatar
Yes, agree, we are not happy with the 1.6 60ft and feel it can go 1.30. The car already has everything you mention except the 15" rear wheel, but we are going to do that soon but will require us retro fitting rear calipers and rotors from a run of the mill CLK350.
Old Nov 21, 2013 | 01:48 PM
  #32
mdgrwl's Avatar
C63 AMG
Hmmmm.... high stall converter and everything huh?
Are you hooking up out of the gate?
If your hooking up and not spinning, a 15" conversion wont do much as traction isn't your issue. What I would do is I would have Weistec look at your tune and add see if they can safely add some timing to the low end. When I drag raced my 10 second SRT8 I was stuck in the 1.7x 60ft and just by a simple tweek of the tune I gained a 1/10th out of the gate and got into the 1.6x 60fts. I was running 17" DR's FWIW.
Great ET overall... get that 60ft down and you'll set another record. 1/10th out of the gate is good for 2/10th up top.
Overall though, Good job mate
Old Nov 21, 2013 | 02:20 PM
  #33
Weistec's Avatar
Former Vendor of MBWorld
Weistec
We have gone a 1.46 60ft in ecambell's CLK Black Series on his 10.01 pass. It is all a matter of track prep, suspension, tire, and possibly some tuning to get the car to no spin like crazy. We will be back at it on December 14th at Famoso. We suspect a mid to low 9 second pass with the small changes we will be making.
Weistec Engineering
Old Nov 21, 2013 | 03:17 PM
  #34
mdgrwl's Avatar
C63 AMG
Weistec Engineering
You forgot one thing. The DRIVER mod -
Old Nov 21, 2013 | 03:34 PM
  #35
Merc63's Avatar
C63 AMG
Engine pics please.
Get those Hooisers!
Old Nov 21, 2013 | 03:49 PM
  #36
deadfission's Avatar
2010 C63 AMG, 2011 Mini Cooper (work)
I wish I had 90% of the problems that you face on track days....
Old Nov 21, 2013 | 04:34 PM
  #37
PelicanParts.com's Avatar
SPONSOR
Good going you guys - so impressive! Could watch those passes over and over.
Mark/Pelican Parts
Old Nov 22, 2013 | 08:06 AM
  #38
mdgrwl's Avatar
C63 AMG
Weistec Engineering
With a proper drag set up the driver shouldn't have to worry about tire spin.
Though this isn't my set up and I wasn't the driver, but this is the "life" I came from - HEMI Drag Racing:
7.85 @ 176mph
Notice the launch.
You should be able to just stomp the gas out of the gate and head hook. Either loading up the verter or flashing the verter... different methods, but the launch with a proper set up and tune should be violent (as you seem to know if a previous car you tuned did a 1.4x 60ft).
You shouldn't tune to avoid tire spin... cars (like above HEMI) are making much more power without tire spin. I suggest adding MORE power, MORE timing at launch. And possibly throwing in a different torque converter as the current one doesn't seem to be launching at a high enough RPM. I've seen guys put in 5000rpm high stall converters...
With the HEMI platform we could Datalog to see exactly what was going on... can you do that with the CLK?
Just trying to help get that record even better mate
Old Apr 3, 2014 | 10:31 PM
  #39
MrBlonde's Avatar
BMW X5, BMW M Coupe
A dead hook is with 10% wheelspin .. that's optimal launch. Funny seeing people complain about a 1.6x short time on a modern IRS car.
Old Apr 3, 2014 | 11:53 PM
  #40
Jons95c36amg's Avatar
02 CLK 55 AMG,09 C63 loaded with P30
Damn! Its a good thing the car is a pig. The weight keeps the power down somewhat.
Old Apr 4, 2014 | 09:51 AM
  #41
blackbenzz's Avatar
haters crazy
Long time no see. What makes you venture onto the mb boards? Btw, my friends IRS car did 1.1 60'
Umm where did you hear this car is a pig?
Old Apr 4, 2014 | 11:15 AM
  #42
jrcart's Avatar
I went 1.41 with the car less than 2 weeks in Texas ago and it was closer to optimum but still more than 10% wheel spin. I think the car is good for a 1.25 60ft.
Old Apr 4, 2014 | 11:23 AM
  #43
blackbenzz's Avatar
haters crazy
Not unless you put a full drag suspension in there and even then it's unlikely.
Old Apr 4, 2014 | 11:50 AM
  #44
I was thinking the stock weight.
Old Apr 4, 2014 | 12:04 PM
  #45
dbasons55's Avatar
I saw that run absolutely mind blowing all the best to you I hope you crack some numbers and raise the bar inspiring just wondering did you get rid off the OEM ECU and swapped it with a motec?
Old Apr 4, 2014 | 12:37 PM
  #46
blackbenzz's Avatar
haters crazy
You thought this car was stock weight?
Old Apr 4, 2014 | 01:05 PM
  #47
VividRacing's Avatar
G63, C190 AMG GTC, W209 CLK63 BS, W208 CLK430
Great work! It is very fun to watch that CLK go down the strip!
Old Apr 4, 2014 | 01:11 PM
  #48
blackbenzz's Avatar
haters crazy
Btw what trans are you running in this car? Rumor is it's not Mercedes
Old Apr 4, 2014 | 02:04 PM
  #49
GeorgeSmooth's Avatar
C63
7.85 @ 176mph
Notice the launch.
That car must be a solid axle car?
Old Apr 4, 2014 | 02:33 PM
  #50
jrcart's Avatar
Gotta love rumors lol. Trans is by no means "stock" nor is anyone claiming it is. I have posted a zillion times about the trans being built over the past year or so and the mishap we had with it 1/8 mile testing out at Irwindale last year when trans blew and parts flew into cockpit and broke Steve's foot in a shake down pass which headed us back to the drawing board to have a special scatter shield fabricated(not much room in there), that's no secret but we are not running a Powerglide in it if that is what you or anyone is inferring. I think anyone can click on any of my or Weistec's YouTube videos from the half dozen or so Airstrip events I have participated in over the past 12 months a see and hear me going through the gears while using the factory paddles, or at least going through 6 of them anyhow I don't think I hit 7th in the 1/2 mile and I did not run the CLK at the Michigan Mile.
