C63 AMG (W204) 2008 - 2015
Headbolt Failure on 2008 C63 Estate
Old Dec 8, 2013 | 02:02 PM
Ingenieur's Avatar
C63 AMG
how hot did the oil get?
what were the outside air temperatures?
when the shop looked at it was there ANY coolant in the system? was it still leaking?
if you were reading water temps you still had some fluid in the system, but some air too, hence the fluxuating readings
it's good you only drove for a minute or so and under low speed/light load
I'm not sure you damaged the tranny fluid in such a short time
I'm not sure it would even get hotter under this scenario (does the tranny have a cooler that used engine water?)
glad it wasn't a big issue
Old Dec 8, 2013 | 02:17 PM
olszowa12's Avatar
'08 C63 Estate
Outside temps were about 0 degrees celsius (32*F)
The oil temp went up to 140C / 284F when I turned off the car.
When I got to the gas station, I checked the coolant level and the reservoir was empty.
But when we moved the car to the tow truck, there were some coolant spots on the parking space.
I will find out on Tuesday if it was minor.
Old Dec 8, 2013 | 04:10 PM
Critter's Avatar
07 E63 + 07 CLK63CAB
2 scenarios, coolant lose was from leak from a crack over a long period, or leak was after pipe burst under 16 PSI and evacuated most of the system. These engines run hot to the touch when operating with full coolant now take that away and the temps rise exponentially. Just I like to side on the cautious and not the Oh I should have spent 500 dollars for oil change and trans service but now I have a 3-5 thousand dollar trans overhaul. Op stated no heat so chances are it was very low on coolant and the trans is cooled by the cooler in the bottom tank. IMO To the op just how low was the broken connection in the system, Good Luck, Hope all is well.
Old Dec 8, 2013 | 04:40 PM
olszowa12's Avatar
'08 C63 Estate
The hose disconnected at a tri-connecter (in the mid-height/middle of the front bumper).
Old Dec 8, 2013 | 07:33 PM
Mort's Avatar
That was an awful scare with all the head bolt issues. I hope the news is good from your Indy shop. Discuss this with the shop and I am sure you will figure out the best course of action. GL
Old Dec 8, 2013 | 07:54 PM
Karl901's Avatar
Porsche 911 Turbo S 2014! E63S 14, Audi S8 13, CLS63 12, E550 12, C63 09, all tuned
If your near 40K + miles many are starting to fail.
I heard MBof Pompano, Fl had 4 alone last month.
Old Dec 8, 2013 | 08:16 PM
  #32
Ingenieur's Avatar
C63 AMG
the tranny cooler is air cooled (not water)
same for the power steering
the upper oil cooler is air
the lower oil cooler is air (with an aux fan)
Old Dec 9, 2013 | 03:17 AM
  #33
olszowa12's Avatar
'08 C63 Estate
So what you are saying is that the tranny oil was not affected by this issue?
Old Dec 9, 2013 | 05:53 PM
  #34
Ingenieur's Avatar
C63 AMG
yes, in my opinion...provided you have been performing the scheduled tranny maintenance per 'the book' I would not change it
if you haven't (and won't in the future) been doing the regular fluid changes (40k miles in the US iirc), I'd do one now...
the tranny is on it's own cooling loop, you only drove it for a minute or two, under light load, in cool temps, and I assmue level ground (at least not pulling a trailer up a mountain, lol)
depending on when your last oil change was I might change it
if you just (a few k ago) did a change, I wouldn't
if you are almost due for one (a few k to go), I would do it now
look at the oil, smell it, sometimes getting it nice and hot (for short period, and not too hot, >350 F) is good, cleans everyhting really well, including the oil itself; burns off the water, fuel and other volitales
if the hose broke at the bottom of the expansion tank (the highest point in the system for a reason) you probably had coolant in the system so it's not as bad is it seems
you noticed it (you'ld be surprise, or perhaps not, how many wouldn't even notice it, lol)
you drove carefully to a safe spot which was only a minute away (many would drive until it stopped due to damage!)
I personally wouldn't sweat it
Old Dec 9, 2013 | 06:03 PM
  #35
olszowa12's Avatar
'08 C63 Estate
I change the transmission oil, filters and gasket every 40'000km.
I'll definitely change the engine oil and filters.
Thanks for all your help. I'll give you guys an update tomorrow.
I hope it's all good
Old Dec 11, 2013 | 01:21 PM
  #36
olszowa12's Avatar
'08 C63 Estate
Ok small update - we replaced the connector but it turned out there still was a leak.
Now I need a new water pump...
Old Dec 11, 2013 | 01:23 PM
  #37
C63Analyst's Avatar
2009 C63
Glad to hear it was just a false alarm, love your car too much to see it die!
Old Dec 11, 2013 | 02:44 PM
  #38
Critter's Avatar
Now did the water pump fail because of normal wear and tear or was it because of running dry and extreme heat?
Old Dec 11, 2013 | 02:47 PM
  #39
olszowa12's Avatar
'08 C63 Estate
I have no idea which died first, but I can only assume it was in this order:
1) hose slipped off the connector
2) water pump died.
The water pump is now leaking coolant at a slow rate.
Old Dec 11, 2013 | 04:57 PM
  #40
avery.whss's Avatar
S550 on order
i know this is off topic.
but is this you matt? looks like fun
Old Dec 11, 2013 | 05:04 PM
  #41
olszowa12's Avatar
'08 C63 Estate
Originally Posted by avery.whss
Sick skills - it looks like Japan or somewhere in Asia.
The sound is insane
Old Dec 11, 2013 | 05:21 PM
  #42
Kriston's Avatar
C63 AMG
Hey Matt, was there an intermittent loss of power? if so, its most likely a faulty water pump. I had my Water pump die on my old 335 and it was almost identical in symptoms of what you explained.
Old Dec 11, 2013 | 05:27 PM
  #43
olszowa12's Avatar
'08 C63 Estate
Exactly. The car didn't have power and I couldn't accelarate at all. I barely got to the gas station.
Old Dec 11, 2013 | 10:40 PM
  #44
Kriston's Avatar
C63 AMG
You got to 160+ KM on your stock water pump - if you have to swap it out now, I say you got good mileage out of your old one. Just some needed maintenance. Hoping she is good to go soon!
Old Dec 11, 2013 | 10:50 PM
  #45
roadtalontsi's Avatar
10 C six trizzle
you never know with water pumps. Typically in the best case scenario they start seeping out of the weep hole and it is noticed during a service. Other times they just start puking or making awful grinding noises as the bearings go out and the blades hit the housing. I've seen them fail at 10k miles and 150k miles. Anytime i see one over 100k thats original i definately recommened replacement. Also good idea to go ahead and replace the thermostat at the same time although benz thermostats usually only stick open not closed and the check engine light will turn on for it but you never know.
Ya dont worry about trans fluid, some of the other cars use coolant for trans cooling but not c63's so your ok on that. Change of oil is never a bad idea with high temps like that - breaks it down much quicker.
Old Dec 12, 2013 | 02:58 AM
  #46
olszowa12's Avatar
'08 C63 Estate
Thanks for the info guys. I've never experienced a broken water pump so it's useful to read some info on it.
I ordered a new water pump from Germany, should be here by Monday.
Old Dec 13, 2013 | 06:03 PM
  #47
olszowa12's Avatar
'08 C63 Estate
Final update: The car is up and running once again
Parts replaced - hose connector, water pump, water pump pulley, water pump gasket, and coolant.
Total cost: $900 including labor.
Oil change coming on Tuesday. Thanks to all for advice and help
One thing I want to mention - we checked the diagrams carefully and we found that the gearbox is cooled with fluid not air. There is a hose that goes from the oil cooler to the transmission.
Old Dec 13, 2013 | 07:24 PM
  #48
Ingenieur's Avatar
C63 AMG
there are 2 hoses that circulate tranny fluid through an air cooled radiator mounted at the main radiator (also one for power steering fluid)
fluid cooled means the engine cooling water is used in a fluid (cooling system water) to fluid (tranny fluid) heat exchanger
it is not
glad it all worked out
http://www.genuinemercedesparts.com/...iagram=5777475
this is the tranny cooler and the power steering is on the top with 2 hoses coming off it
6 is the tranny fluid thermostat and the hoses are not shown (2 going to the tranny)
Old Dec 13, 2013 | 08:25 PM
  #49
Kriston's Avatar
C63 AMG
Good to hear she is back up and running buddy!
Old Dec 13, 2013 | 11:48 PM
  #50
DuaneC63's Avatar
AMG GLC63. Audi R8
It turned out to be a three-way hose connector (I don't know how to call it) is broken. All of the coolant dripped out on the plastic shield below the engine.
The car should run fine once the part is replaced and coolant is filled up.
Thank your guardian angle. Your first post screamed failed head bolts. You lucked out. Best of luck in the future.
