C63 AMG (W204) 2008 - 2015
For the wheel and tire experts
Old Feb 1, 2014 | 10:52 AM
SROC276's Avatar
2010 C63 P31 AMG
What is the widest wheel tire combinations you can run front and back without rubbing assuming lowered by 1inch all around. No wide body and rolling the fenders. Looking for offsets and tire sizes. Thanks in advance.
Old Feb 1, 2014 | 11:40 AM
Roswell's Avatar
2010 C63 AMG, 2009 ISF , 2002 L-Tuned IS300, 2011 ML350
19x9 +38 w/245-35-19 front
19x10 +53 w/275-30-19 rear
This combo was what I had in mind before ordering my HRE, but was suggested smth less aggressive.
Fitting 285/30/19 on our cars w/o rubbing is tricky. U would need +55mm & higher offset.
Old Feb 1, 2014 | 01:13 PM
SROC276's Avatar
2010 C63 P31 AMG
Excellent thanks
Old Feb 1, 2014 | 01:31 PM
Jason Anthony's Avatar
2013 C63 AMG Coupe
i'm using HRE p44sc with 20x9 up front and 20x10 in the back. super sports with 285/25/20 in the back. no rubbing. dropped on kw v3
Old Feb 1, 2014 | 01:41 PM
momo style's Avatar
C 63 AMG 507 Edition
Jason, can you post some pics pls ?
Old Feb 1, 2014 | 03:01 PM
avery.whss's Avatar
S550 on order
I have 20 inch VS-160 wheels with 285s on the back with a 30 series tire and 245 on front with a 35
Old Feb 1, 2014 | 04:24 PM
Roswell's Avatar
+63 *drool*
What offset are ur 20x10? +55?
Old Feb 1, 2014 | 06:54 PM
SROC276's Avatar
2010 C63 P31 AMG
What offsets are the wheels?
Old Feb 1, 2014 | 09:07 PM
CarHopper's Avatar
E63S | X5
FWIW I have 10.5's in the back, I believe the offset is 52. Running a 275 PSS on it lowered on H&R Springs. No rubbing issues.
Old Feb 1, 2014 | 09:20 PM
Roswell's Avatar
Stretching 275 on 10.5 must help clearance. Do u think 285 will clear?
Old Feb 1, 2014 | 09:26 PM
CarHopper's Avatar
E63S | X5
^ Don't think so. I rubbed 1 time with the car on an embanked shoulder with 5 people in the car. That being said, I think a 285 COULD work, but I feel like it would rub under less extreme circumstances.
I could always try?
Old Feb 1, 2014 | 10:03 PM
Roswell's Avatar
Yeah, if ur wheels are indeed +52mm, 285 will need at least +55mm.. But again ur 10.5 might help with a little stretch.
Old Feb 1, 2014 | 10:08 PM
CarHopper's Avatar
E63S | X5
Yea, like I said I bet it would work under perfect conditions IE flat roads. I have to go over 2 sets of railroad tracks on my commute, one of which is pretty brutal, and I think I would rub there. Other than that on otherwise flat roads I'm sure I'd be fine seeing as I never have people in the car. I've had 5 people in it once and rarely 2 including myself.
Old Feb 1, 2014 | 10:45 PM
Roswell's Avatar
Do itttttt, 285 on 10.5 is pretty baller for our cars. Lol
Old Feb 1, 2014 | 11:39 PM
CarHopper's Avatar
E63S | X5
Maybe I will try on a more aggressive tire than the PSS. I feel like the PSS will work best at 275 for me.
Maybe a drag tire or something like that.
Old Feb 2, 2014 | 12:06 AM
Karl901's Avatar
Porsche 911 Turbo S 2014! E63S 14, Audi S8 13, CLS63 12, E550 12, C63 09, all tuned
Yeah I track 255/285, no rubbing Dunlop Race MAXX sports.
Tracking 265/265 Hoosier run great too.
But daily driver 245/275 works best.
Old Feb 2, 2014 | 12:16 AM
CarHopper's Avatar
E63S | X5
^Agreed
Old Feb 2, 2014 | 03:51 PM
mattc63_Nuke's Avatar
MB 2009 C63 AMG
Stock 5 Spoke Rims Rear / WIDEST Soft Tires?????
The C63 was ECU tuned from Weistec increasing power 545HP/502lb/ft
My C63 has Stock Rims w/ 255/35/R18 Tires. I want to lower the Car w/ H&R Springs. But I also want to get some badly needed Grip for the Rear Tires.
0-60 3.84 and one run at 0-60 3.79 Start is lightly Downhill 3-5 degrees
They Break Loose at any speed up to 65mph. The Tires are Goodyear Eagle F1 300/AA/A
I want to know how wide a rear tire can be fit 265 or 275 or 285 & Still lower car 1.2 in rear and get some Gosh Darn GRIP. In 1500 miles I have Lost 1.8" tread. I tried different pressures to no avail.
I know I need a Softer Tire, But how wide can I safely Go and not Rub when lowered????????????????????
Old Apr 17, 2014 | 01:58 PM
synacide's Avatar
C63, M5
I am running Continental DWS 265/30/20 on 9x20 in Front , Pirelli P-Zero 265/30/20 on 9.5x20 in Rear dropped on KW V3. There is no rubbing on normal driving.
Attached Thumbnails For the wheel and tire experts-photo-3.jpg   For the wheel and tire experts-photo-4.jpg
Old Apr 17, 2014 | 03:28 PM
I am Jeff's Avatar
Steel Grey Metallic C63!!
Wait...You're running a square setup? 265/30/20 all around?
Old Apr 17, 2014 | 04:49 PM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
To make throttle lift over steer easier
Old Apr 17, 2014 | 07:59 PM
synacide's Avatar
C63, M5
yup i like it but what do i know. is this a bad thing that ive done?
