C63 AMG (W204) 2008 - 2015
What mm spacers?
Old Aug 12, 2014 | 02:00 PM
D7reU's Avatar
C63
What mm spacers?
Hi, I am installing H&R Springs (-20mm).
I have a 09 P30 with 19". Also running 265 on the rear.
Which spacers would be best for me?
Any recommendations?
Thanks.
Old Aug 12, 2014 | 06:04 PM
charliekay's Avatar
C63 AMG
12mm for the front if you are running stock 235s.
10mm for the rear, but that depends on the tyre brand as some 265s are wider than others.
Some people have run 10mm with 265s and it has worked, I am pretty sure Michelin PSSs in 265 and 10mm spacers will rub on a drop.
Old Aug 12, 2014 | 06:33 PM
bhamg's Avatar
C63 AMG
Originally Posted by D7reU
Hi, I am installing H&amp;amp;amp;R Springs (-20mm).&amp;lt;br /&amp;gt;&lt;br /&gt;<br />
I have a 09 P30 with 19&amp;amp;quot;. Also running 265 on the rear.&amp;lt;br /&amp;gt;&lt;br /&gt;<br />
Which spacers would be best for me?&amp;lt;br /&amp;gt;&lt;br /&gt;<br />
Any recommendations? &amp;lt;br /&amp;gt;&lt;br /&gt;<br />
Thanks.
This should help. On H&R coilovers, 3/4" drop from OE P30 suspension, 265 PSS on 19" et50 rear wheel, occasional rubbing but only on medium to severe compression dips. I was surprised and somewhat disappointed that it rubbed at all.
Old Aug 12, 2014 | 10:59 PM
149max's Avatar
Running 275/30 PSS w/ a 10mm spacer.
Lowered. No rubbing here.
Old Aug 13, 2014 | 05:37 AM
D7reU's Avatar
C63
what about the front mate?
Old Aug 13, 2014 | 10:29 AM
Roswell's Avatar
2010 C63 AMG, 2009 ISF , 2002 L-Tuned IS300, 2011 ML350
Really? I doubt you are using oem wheels with the 10mm spacers + 275/30 PSS cuz you would be rubbing like crazy.
I'm running OEM multispokes with 10mm spacers but with 255/30 AVS no rubbing. Since you have 265/30, I will say you will rub with the 10mm spacers... try 5mm.
As for the front, 19x8 +45 with 12mm spacers & 235/35... no rubbing. But you can go up to 15mm with 235/35.
Old Nov 7, 2014 | 11:31 AM
rickclass's Avatar
2014 C63 AMG 507 Edition
Roswell...thinking of getting wheel spacers for my 507 sedan, called a local performance shop and the recommended against it, said it will shake and not ride as smooth factory and that you'll go though tires 2x as fast? any truth to this? I don't want to compromise the ride at all. Thanks
Old Nov 7, 2014 | 01:21 PM
Roswell's Avatar
Make sure the spacers are hubcentric & u buy longer bolts equivalent to the thickness of spacers. In example oem bolts 27mm + 10mm spacers = 37mm bolts... Then u won't have any problem.
But yes, spacers should be with caution. Torque wheel bolts at 96-100lbs regularly.. And not recommended for track use.
Old Nov 7, 2014 | 01:40 PM
rickclass's Avatar
Great thanks...guy said they installed on 09, and 11, and the ride shook? so I'm thinking 265/35/19 R and 245-35-19 F should I go with 10mm R and 12mm F? or 10mm all round?
Old Nov 7, 2014 | 03:29 PM
Roswell's Avatar
The shop definitely didn't install the h&r hubcentric spacers if the cars start shaking. I'm running spacers on my oem 19's for 2-3 years not a single vibration.
As for ur planned set-up, first go 265/30/19 vs 265/35/19 which is too tall.
And are u lowered? If yes, ppl said they rub with 265/30/19 & 10mm spacers & lowered. And I don't think 5mm spacers comes hubcentric so stay away from it.
Ur front will work fine with 10mm-12mm, even 15mm to the extreme.
Old Nov 7, 2014 | 04:27 PM
rickclass's Avatar
No , Im not lowered (I don't plan to be), but I really like the 256/35/19/245/35/19 (like the new 205), I was told I should be ok...I like a bit more sidewall...fill in the void and a little better protection for the wheels (in my mind anyway)...
Old Nov 7, 2014 | 08:35 PM
Roswell's Avatar
If u stay at stock height, u will be ok with 10mm spacers.
265/35 might work but again be prepared to hear some possible grinding noise in the rear if u have passengers or hit a bump. Lol
Old Nov 7, 2014 | 11:17 PM
rickclass's Avatar
Thanks...so you think the 265/35 Rears may rub with 10 mm spacers? but on the F with 245/35 12 mm spacers I'll be ok?
Old Nov 8, 2014 | 01:03 AM
Roswell's Avatar
Front will be perfectly fine... and rear should also be fine in normal driving conditions since you are at stock height.
I'm just saying the taller 265/35 might touch the rear fenders if you have passengers or hit big bumps at high speed. Other than that you will be fine.
Old Nov 8, 2014 | 01:13 AM
Ingenieur's Avatar
C63 AMG
Heights
235/40/18 25.4 oem front
245/40/18 25.7
255/35/18 25 oem rear
265/30/18 24.26 too short imho
265/35/18 25.3 perfect match for oem front
I'm running PSS's
245/40/18 w/12 mm
265/35/18 w/10 mm
Fronts rub a bit under down hill compression turns
The PSS have square shoulders, the Conti may not rub
When I replace tires I'm going
F oem 235/40/18 imo the 245 dull response and tramline a bit, compromise directional stability
R 265/35/18
Old Nov 8, 2014 | 04:47 AM
dchl21's Avatar
Gallado Spyder / AMG C63S / Cayenne
stock p30 suspension, oem 19s , 12mm front and rear , conti 235 40 18 / 265 35 18 no rub
Old Nov 8, 2014 | 09:07 AM
rickclass's Avatar
Thanks guys for the responses....
Old Nov 8, 2014 | 10:37 AM
Roswell's Avatar
Originally Posted by Ingenieur
Heights
245/40/18 25.7
I'm running PSS's
245/40/18 w/12 mm
265/35/18 w/10 mm
R 265/35/18
Ingenieur is correct, 265/35 is good to go on 18's ... but it will be beefy on 19's. Again, you will be fine on stock suspension like dchl.
Old Nov 28, 2014 | 09:34 AM
Illegal Machine's Avatar
'10 P30 C63 AMG
Buuump for more questions.
I've got H&R springs, and I'm about to put 265/35/18 NT05s on. Will I be good on 10mm spacers?
Old Nov 28, 2014 | 02:35 PM
Roswell's Avatar
PM'ed back bro
Old Nov 28, 2014 | 11:00 PM
'10 P30 C63 AMG
PM'ed back bro
<3 !!!!!!!
