Do all C63 pull to the right after H&R sport springs are installed?
#101
bolts are only about 20$ each from the dealer. They arent crash bolts people. they are adjustment bolts. Id go ahead and get 2. pull left trol arm in and push right control arm right. Your car should have a pretty healthy pull to the right with those specs.
And to the post above this. - Crya - If you are a notch off on the steering wheel the only way to really know is looking at actual values of the steering angle sensor. I'd highly recommened leaving it as is unless you know its messed up. the Steering wheel position can also be adjusted with toe adjustment. go get an alignment if you're concerned - from someone who knows what they're doing.
curt.r (07-16-2018)
#102
I'm going to go to the dealer on Monday and see what they quote me for 2. From OEPartsDiscount I found it was the cheapest at $20.62/bolt. Most likely I'll be purchasing them online as MB Pleasanton loves to have a huge markup on their parts (I'm predicting they'll charge me upwards of $28/bolt). I read people calling them crash bolts, so naturally I assumed that was the bolt's name... but we all know what happens when people assume; adjustment bolts, got it. As far as the pulling goes, I wouldn't describe my car having a healthy pull to the right. I would say it is more sensitive to the crown of the road. On flat ground (i.e. a parking lot) it drives straight but on a crowned road it pulls left or right respectively. I thought the same as you after reading my specs, but surprisingly not. Thanks roadtalontsi for your help, your advice solidifies my dilemma of 1 or 2 bolts. I will keep you guys updated.
#103
#105
Just wanted to give an update since I lowered the car. I have the bolts, but haven't put them in yet (stupid me, I know... kicking myself for it but it will all makes sense after reading this). I've put around 2,000 miles on the car since then and like @roadtalontsi stated, I do have a pretty healthy pull to the right. Must have something to do with the springs settling, or I have no clue... The pull became more noticeable as the miles rolled on. It's nothing too bad, just getting to the point where I'm tired of constantly steering a degree counterclockwise to counteract it. I also decided to check my tires and see how they're wearing from the excessive camber I have in the front. The rear tires are doing OK, no excessive camber wear, but the fronts are not doing so well. They have worn down all the tread on the inside of the tire (no cords showing yet, thankfully). I've decided to stop driving the car as of now and it has been sitting for the past couple weeks. I've decided that there's no use for installing the adjustment bolts, as it will not fix my problem. I'm going to be placing an order for the K-MAC front camber/toe bushing kit and having that installed by a shop. I'm at the point with my tires where I can still save them as long as I correct this issue now. These MPSS's are less than a year old and have 75% tread life left. Very disappointed in myself for trying to save a few bucks... once the bushing kit is installed I'm going to take off the wheels and do a through inspection of the tires.
Here is the link & part number to the K-MAC bushing kit if anyone is interested: https://k-mac.com/product/mercedes-w...shing-502616k/
Part Number: 502616K
#106
I would get the toe corrected as soon as possible before installing bushings.
#107
#108
Your tire wear is most likely due because of negative toe more than the camber. I just went through the same issue and just replaced my front tires. It's the second car I put the springs in and both had the same issue.
Yeah, I got an alignment done a week and a half after the springs got installed to allow for settling. I attached my alignment specs below:
Attachment 440902
#109
Interesting... I guess it'll be worth a shot to get the toe adjusted, but the camber is still way off. I have a decent amount of camber in my driver front side. I had the car aligned after the springs settled a couple months ago and I attached the specs below.
. It could be that your tires wore out just during the time between spring install and alignment.
Going by your current alignment your car should be pulling to the left.
#110
#111
Of course they are done and already replaced.
#112
It could be possible, but being that I only put about 300 highway miles on my car (maybe even less) while I was waiting for the springs to settle it is not likely. The car is definitely pulling to the right, I've never heard of a W204 pulling to the left after an H&R spring install.
#113
Thats why I said try to rotate your tires and see if it still pulls to the right. The wear of your tires could cause it to pull.
#114
My CLS550 had a slight pull to right. Installed Camber bolts to reduce inner tire wear. Installed caster bolt on passenger side only to stop pull. Then had alignment and all is perfect.
#115
Going by your alignment sheet it should slightly pull to the left. The before values indicate pulling to he right the curren to the left.
#117
[QUOTE=curt.r;7555580]Oh. IIRC, the MPSS have a dedicated outside tirewall, although I'm not 100% sure so don't quote me on it. I'll mention it to the indy shop I'm going to use before I buy the bushing kit.
Yes they have a dedicated outside wall (asymmetrical tires) and if we move the left wheel to the right and the right wheel to the left. The outside wall stays on the outside.
If you have directional tires you wouldn’t be able to rotate them.
MPSS are asymmetrical and can be moved.
#118
#119
Oh, that makes more sense. I misunderstood you and thought you were telling me to have the tire shop flip the tires and put the outside sidewall on the inside. I guess it’s worth a shot, if I have time today I’ll go ahead and try it, and report back. Both tires have inner tire wear the passenger one just has less.
#121
Going to be getting the K-MAC Front Camber/Caster Bushing Kit. https://k-mac.com/product/mercedes-w...shing-502616k/
I'll definitely keep everyone updated once I get the bushings installed on the car.
#123
Time for an update. Got around to having the shop install the KMAC front camber/castor bushing kit. If anyone needs anything for your Mercedes or AMG, give Kahlers in Dublin, CA a call. Raul and his guys there are awesomeThey knocked it out of the park for a great price as well. IIRC, I might have said negative things about them in the past but they have went above and beyond, and have redeemed themselves. While it was at the shop I had the change the trans & diff fluid, so I'm set. Anyways, back on topic.
My $.02 if you're thinking about installing H&R lowering springs on your W204... don't. The lowered look is aggressive, but have aggressively eaten into my wallet . After installing the springs, the car developed a strong pull to the right, which was not able to be corrected by an alignment. It was to be expected, so I bought the adjustment bolts to correct the issue, but by then it was too late. The incorrect alignment ate through my MPSS's and I realized that I would need the KMAC bushing kit to correct the issue, not help it with the alignment bolts. The installation of the H&R springs (granted you could install this yourself, I preferred to have a shop do it) was $300. The KMAC bushings set me back $510 shipped. To install the bushing was $768 after tax (including the price of the alignment, which took multiple hours to get right). All in all, to lower the car 0.75" I have about $1,600 into it. It looks great, and the handling was improved but if I had the chance to do it all over again, I'd probably pass.
On a side note, Kevin and the guys over at KMAC are awesome! Also, Kevin if you're reading this, sorry for my spotty responses haha... the phone call quality was very poor and I was trying my best to make out what you were saying because the phone kept breaking up. Nonetheless, when I called Kevin, he spoke to Raul on the phone and personally made sure that the shop correctly used the adjusters on the bushings and everything went OK with the install. . The bushings are awesome and the steering pull is almost non-existent now. It's just the excessive wear on my tires causing the ever-so-slight pull to the right. Once I get new tires the pull will disappear, no doubt about it. Highly recommend KMAC bushings if you're in need of a camber correction on the W204.
silversleeper48 (01-22-2019)
#124
I totally agree with you Curt.r . There are way too many people just going the cheap route and end up very disappointed with the car. Sure it looks good but it changes so many thing on the car. The shock is no longer in its center point so that makes it ride stiffer, the sway bar is now loaded at all times (unless you get adjustable sway bar links - which no one ever talks about) which makes the spring rate even higher. Now the camber is even more aggressive than previously which is alot for a street car to begin with. Sadly some 200$ set of springs made your car drive like cheap honda that nukes a $1000 set of tires. Is the change in suspension geometry worth it to lose an inch off the center of gravity? is the handling actually improved? Lots of unanswered questions remain. I truly recommend only using quality coilovers, if you're going lower than stock - get adjustment to fix the camber and sway bar endlinks.
I cant begin to tell you how many peoples car's have been lowered and I talk them into raising them up (typically coilover sleeves setups that are slammed). They are blown away at the ride quality improvement and better handling. Running -3 degrees of camber handles awesome on a tire made for it. No street tire is made for that and it will make it handle worse.
#125
