General upgrade info
Hello, i know plenty of thread and sticky, I would know
What is the best mod i can starting to make to the baby where it will arrive.
- First thing, can i swap the Dashboard With the new model?
- brakes upgrade what is the best and can i find used calipers? Do you have the code?
- body kit or Bumpers advice
- side mirror new model and eventually Carbon fiber cover
- interior Carbon trim.
- DYI on everithng reguarding the car.
performance upgrade (no supercharger) just remap
- sport differential like the Black series is possible?
- removing the cat and new exhaust with sport cat
- command upgrade
the very First thing i do it will be the head bolts.
thanks
- command upgrade
thanks
Received 2,810 Likes
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
LOL
I'm sorry, what? Very dangerous kemosabe, you go first, (oh you did).
'13 C63 AMG P31
- command upgrade
thanks
- command upgrade
thanks
- No
- No need to upgrade brakes. You can always paint the calipers.
- No, unless you want to venture down the black series path.
- Yes, RWCarbon
- Yes, member Matt @olszowa12 makes great carbon pieces (example). Reach out to him if interested.
- It can be dyi on everything if you have the knowledge and time. A lot of members work on theirs.
- Member @hachiroku can help you with a tune. There is also Eurocharged, Renntech and many other types of tunes, do your research for what you want.
- You can get a LSD like Wavetrac or Quaife. If you want to spend a bit more, there is the OS Giken.
- Just remove the secondary cat and replace with straight pipe (keep resonator). Will make it a about 25-35% louder but keeps the deep AMG sound.
command upgrade
- Just have to deal with it. It sucks but not really much better options out there (unless you want to transplant a screen/android device into the spot).
The following 4 users liked this post by INS1GNIA:
All this stuff is easily found if you take a bit of time and look. This should help get you started.
- No
- Yes, RWCarbon
command upgrade
- No
- Yes, RWCarbon
command upgrade
'13 C63 AMG P31
James115 (03-30-2022)
This thread should give you all the info you need Exhaust info for a noob. @Mikegpr03 makes a power pipe if you want to go that route (example).
