PFL 11' RPM Needle Cluster/Tach issues. Any suggestions?
It's been an intermittent issue with only the RPM needle light going out at random. There are times where the needle is lit but very dim and it jumps back to normal and there are times where the RPM needle light is completely out and doesn't come back at all for a few days. Everything else works (including the Red 'Redline' indicator)
I'm wondering if my RPM needle LED is going bad or there is just a bad connection joint behind the cluster.
Anyone else have this issue? Anyone try upgrading to a 2012+ FL tach?
Thanks guys
Thanks guys
