C63 AMG (W204) 2008 - 2015
AMG3.2's DIY Headbolt Adventure
Old Sep 25, 2016 | 05:48 PM
  #76
Mort's Avatar
All done. Here's to you for tackling this difficult job on your own. Nice support from the members as well. Congrats.
The tappet noise is likely just the new lifters filling up to pressure with oil and the smoke just burning off a little oil from the headers as you said.
Time to dump the oil?
Old Sep 25, 2016 | 05:50 PM
  #77
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
Sounds like buckets still pressuring with oil.
Vid of hissing sound?
Old Sep 25, 2016 | 06:03 PM
  #78
chrisridebike8's Avatar
'10 C63
So how much would you charge to do this to my car?
Old Sep 25, 2016 | 06:09 PM
  #79
AMG3.2's Avatar
C63 AMG, P30
Yup - draining the oil as we speak so I can go for a drive. Yes, thanks to all that have helped out. Definitely could not have taken on a project like this without their guidance.
Yeah tappet noise is virtually gone.
I can't get this video to upload right now but it sounds exactly like this:
You don't want me doing this to your car lol I'm pretty sure I didn't even do this correctly on my car.
Old Sep 25, 2016 | 06:18 PM
  #80
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
Will wait until you upload the actual vid. But was your AC running?
Old Sep 25, 2016 | 06:44 PM
  #81
AMG3.2's Avatar
C63 AMG, P30
Video of hissing noise:
http://vid77.photobucket.com/albums/...pscfybidro.mp4
Thanks for helping me out! I can't recall if the ac was running, but I don't think so.
Side note: extracting the oil now and it looks to be pretty chocolate milky.
Old Sep 25, 2016 | 07:00 PM
  #82
BLKROKT's Avatar
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
I know this is not a very educated guess, but have you checked all your vacuum lines?
Hoping for the best man, big kudos for doing this.
Old Sep 25, 2016 | 07:10 PM
  #83
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
Sounds like the intake pipe (the Y that connects to the IM) releasing pressure. That plastic box in the middle of it holds a vacuum.
Old Sep 25, 2016 | 07:14 PM
  #84
AMG3.2's Avatar
C63 AMG, P30
Thanks. As am I.
Alright, let me poke around back there and see what I can come up with. I'll report back.
Old Sep 25, 2016 | 07:35 PM
  #85
GRP's Avatar
GRP
2010 C63 and 2018 GLC63s
Respect for giving this a go and thanks for documenting it all.
Hope everything settles back to normal for you.
Old Sep 25, 2016 | 07:38 PM
  #86
Vladds's Avatar
2010 C63 2019 GLA45
http://s71.photobucket.com/user/vlad...wfnkl.mp4.html
This is mine, with the bellows removed like you have it, when turning off. I hope this helps.
Old Sep 25, 2016 | 08:20 PM
  #87
AMG3.2's Avatar
C63 AMG, P30
Thanks. Appreciate it.
Thanks.
Update: Changed the oil and tighten up the airboxes/y pipe fitting. I didn't remove the y-pipe I don't know why it'd be loose. I'll have to take a look again but I'm just a bit beat for now.
On that note, took the car for a 60 second drive and the dash lit up with ABS, ABR inoperable.
Steering also got insanely hard. More hoops to jump through.
Old Sep 25, 2016 | 11:35 PM
  #88
mr747's Avatar
c63
that hissing sound could be the PCV
Old Sep 26, 2016 | 12:37 AM
  #89
AMG3.2's Avatar
C63 AMG, P30
I didn't remove nor touch the PCV though. In fact, I kept the y-pipe in tact and only removed the airboxes which is why I'm so confused.
Oh well, will look into in soon. A bit burnt out at this point.
Old Sep 26, 2016 | 12:44 AM
  #90
Merc63's Avatar
C63 AMG
Did you put the pulley back on and the belt correctly.
Old Sep 26, 2016 | 01:25 AM
  #91
AMG3.2's Avatar
C63 AMG, P30
Just checked -- yup. I'm only getting the error codes after actually driving from a minute or so.
I could rev or idle all day in the driveway and not throw the codes which I why I ruled out belt install issues.
Old Sep 26, 2016 | 09:43 AM
  #92
Merc63's Avatar
C63 AMG
Speed sensor on all 4 wheels plugged in?
What exactly is happening for codes and not working?
Old Sep 26, 2016 | 11:45 AM
  #93
AMG3.2's Avatar
C63 AMG, P30
Uh - I think so. I didn't touch anything speed sensor related as far as I know.
So this is exactly how the code is acting up.
I start the car - no codes. Rev it, let it idle, no codes. Then I drive it for 45 seconds or so and the car says "Brake ABS, ABR, ESP not available" or something along those lines.
While that happens, the power steering becomes progressively harder and harder.
Old Sep 26, 2016 | 12:43 PM
  #94
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
What codes do you see from the ESP module? I have a lot of experience with that fkn thing.
Old Sep 26, 2016 | 01:07 PM
  #95
AMG3.2's Avatar
C63 AMG, P30
This is what I get from my code reader:
ABR Adaptive Brake ESP_E1
Control Unit N30/4 ESP, Internal Fault 5000 5944
Old Sep 26, 2016 | 01:14 PM
  #96
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
It's likely completely unrelated unless you hit the module while doing the HBs.
I would try re-seating the connector then clearing the codes and run the diagnostic on the ESP module.
For Reference --> https://mbworld.org/forums/c63-amg-w...-steergin.html
Old Sep 26, 2016 | 01:37 PM
  #97
AMG3.2's Avatar
C63 AMG, P30
I know with 99.5% certainty I didn't even touch that module. Not even while torquing the bolts down, etc.
It's the weirdest thing. At this point, I'm praying it's a battery low issue or something 1 off but I doubt it.
I don't have STAR, but I'll reseat the connector, clear the code, take it for a quick spin and report back. Thanks.
Old Sep 26, 2016 | 01:46 PM
  #98
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
What code reader do you have? Most can do the full scan on the module. I don't mean the STAR diagnostic DAS scan.
My module has been flaky for a year or so now. The last time it faulted for a few weeks then magically fixed itself.
If you have access to monitor all the ESP sensors make sure they are reporting data properly.
EDIT: The fact you just have the generic faults (other faults are specific to an ESP sensor) it's likely a flaky module which could potentially be power related.
Old Sep 26, 2016 | 02:49 PM
  #99
AMG3.2's Avatar
C63 AMG, P30
I've got a Autel AL619. Also, re: being power related, I unplugged my battery during the HB install... not sure if that could be related?
Old Sep 26, 2016 | 03:10 PM
  #100
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
Clear the codes, see if they come back. I have them not come back after clearing before.
