C63 AMG (W204) 2008 - 2015
AMG3.2's DIY Headbolt Adventure
Old Sep 25, 2017 | 01:43 PM
  #201
m3driver's Avatar
09 C63, 04 CTS-V (just sold), 06 325, 15 500e, 96 NPR, 05 C172
Originally Posted by AMG3.2
Cool. Well check it out then.
Re: pulling the motor, I'll assume they meant heads, but if the head gasket hasn't been compromised (aka not consuming coolant), the consensus is that you should completely fine replacing one bolt at a time.
Just ordered your DIY guide. Looking forward to reading it. I'm sitting on the fence about doing the swap. I've asked a few indy shops in the DC area and both told me not to waste my money on doing the swap. One shop had 3 MB techs with about 100years experience between them and none had seen the problem. But now that I'm back in the SF bay area and have access to all my tools I'm thinking about a DIY. I like the weistec kit but damn they are pricey. My cost for a ARP BMW S65 V8 head bolt kit is nearly 1/3 that. I'll just assume the 625 plus material is really expensive ;-) Funny that wesitec aren't CARB legal (But that hasn't stopped me before) Like the head bolts are going to effect emissions....
thanks
Marco
Old Sep 25, 2017 | 03:18 PM
  #202
AMG3.2's Avatar
C63 AMG, P30
thanks
Marco
Just granted you access to the pages. Feel free to PM me if you have any questions.
Old Dec 23, 2017 | 10:33 AM
  #203
KECLS63's Avatar
2007 cls63
Originally Posted by Mag1c Carp3t
Not sure about your cls but the c63 motor is required to be removed for studs due to clearance issues when installing the heads on studs. If you opt not to use the water jackets than the studs can be installed with the heads on. Also studs are not required as the revised headbolts are plenty for a blower.
Thanks for the response. I still own the car at 81k miles and after re-reading this thread feel very motivated to do this job. Seems like i am running into the age and usage where failure risk is increasing a fair amount.
Old Dec 23, 2017 | 10:30 PM
  #204
bhamg's Avatar
C63 AMG
And by the way, if you're looking for a more in depth DIY (step by step), I've started a site (www.diytechnica.com) where you can purchase a more in-depth DIY for 10 bucks. But if you don't want to go that route, happy to answer any questions you may have about the process here.
I just took a look at it. Great idea and very fairly priced. A no-brainer for most who are contemplating this job.
Old Dec 28, 2017 | 09:02 PM
  #205
KECLS63's Avatar
2007 cls63
AMG3.2 i wanted to PM you about the download being partial, but your message box is full. I have only access to pages 1,10-14 and not others. Look forward to access to the others.
Old Dec 28, 2017 | 11:33 PM
  #206
AMG3.2's Avatar
C63 AMG, P30
Originally Posted by KECLS63
AMG3.2 i wanted to PM you about the download being partial, but your message box is full. I have only access to pages 1,10-14 and not others. Look forward to No access to the others.
Hey, just checked your account and it looks like you do have full access to all of the pages. Can you please double check and make sure to scroll down all the way on the popup?
Old Sep 15, 2018 | 08:30 AM
  #207
BenzKompressor's Avatar
'04 C230 Kompressor Sedan
Damaged cam!
I am in the middle of this job, myself. I’ve got the left side done. What prompted me to start tearing my beloved engine apart was a ticking lifter that never went away. I swore it was from the left side. All the lifters and cam lobes looked perfect. After installing the revised head bolts and lifters on the left, I moved on to the right. Opened up the valve cover, double checked correct timing, pulled the cams, and found the rear lifter on cyl 8 beat to hell and the cam lobe ground down. So, I ordered a brand new right side intake camshaft.
Thanks for this thread! Between here, Tasos on YouTube, WIS, and a buddy who is a dealer tech at Arrowhead MB in AZ... I got the information and confidence to tackle this job myself. It’s really not THAT bad of a job. Most nerve racking part is fearing getting the timing wrong and the head bolts snapping upon removal. I got all 20 bolts changed. Only issue I had with the head bolts was getting too excited and when removing the socket from the bolt, it got snagged on the head and disconnected from the torque wrench. The sound of a socket dropping INSIDE an engine makes your heart go into your throat. But, don’t panic, it cannot go anywhere but between the two head bolts and it is possible to get out with a little patience.
Thanks again!
Last edited by BenzKompressor; Sep 22, 2018 at 04:14 PM. Reason: Trying to add pics. Typo, 20 head bolts changed, not 10!!
Old Sep 22, 2018 | 04:11 PM
  #208
Just wanted to update that I successfully completed the job. Had one snag to fix: I got the right side intake cam actuator wire pinched under the valve cover and shorted it out. This caused the motor to idle like **** (think ‘60s muscle car with a performance cam). I got the wire out and soldered it back together. Motor fired right up and is running perfectly. Valvetrain sounds better than when I bought the car two years ago. Glad to have my little beast back!
Old Jan 29, 2019 | 06:12 PM
  #209
kkkk's Avatar
W204 C63 Estate
are these parts necessary?
Cylinder Head Gaskets 1560162221 $6.00 2 $12.00
Valve Cover Gasket Left, 156-016-25-21 $19.89 1 $19.89
Valve Cover Gasket Right, 156-016-24-21 $19.89 1 $19.89
Spark Plug Gaskets, 1560162121 $5.85 8 $46.80
​​​​​​​Diamond Washers 4x 1560510275
or can I just order the bolts and lifters
Old Jan 30, 2019 | 07:45 AM
  #210
If you’re not pulling the heads, you don’t need the head gaskets. Everything else is required. I’d also get new cam phaser bolts (holds the cam adjuster to the camshaft).
Old Jan 30, 2019 | 11:08 PM
  #211
kkkk's Avatar
W204 C63 Estate
I havnt put the part numbers for the head gaskets as i not pulling heads.
So the final order would be
Lifters SLS - 156-050-02-25 x 32
M156 Updated Headbolt x20 156-016-07-69
Cam bolts x32 000000003236 x 32 - are these necessary (I noticed the original post didnt have them)
Actuator Bolts x4 910105-012018 - are these necessary
Timing Case Bolts x8 000000001150
Front cylinder head/timing cover gaskets 2x 1560162221 - i think these are the cam adjuster gaskets?
Valve cover gasket LEFT 156-016-25-21 - again can I reuse current one
Valve cover gasket RIGHT - 156-016-24-21
Spark plug gaskets for valve cover 8x 1560162121. - can I reuse my current ones?
O ring around spark plugs 8x - 013 997 23 45 - are these necessary?
Diamond Washers 4x 1560510275 (is this the bolt that holds the cam adjuster to the camshaft)?
Ill also do the pin flip for the cam adjuster while im at it.
Is it necessary to change the gaskets for the cam adjuster and valve cover gasket or can I re use my current ones? What about the spark plug gaskets and o rings?
Old Jan 31, 2019 | 08:51 AM
  #212
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
Yes, change ALL the gaskets.
Old Jan 31, 2019 | 04:06 PM
  #213
TPete19's Avatar
2010 C63 AMG, 2010 GLK350
Correct me if I'm wrong, but you'll be pulling the intake manifold off in this process, right? If that's the case, you'll need to replace those bolts too as they're TTY and shouldn't be reused. You could likely reuse the IM gaskets, but may as well replace while you're in there.
Old Jan 31, 2019 | 04:42 PM
  #214
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
No, you don't touch the IM.
Old Jan 31, 2019 | 07:44 PM
  #215
kkkk's Avatar
W204 C63 Estate
What about the spark plug gaskets and o rings for the spark plugs
Old Feb 3, 2019 | 06:57 AM
  #216
kkkk's Avatar
W204 C63 Estate
What's the order to unbolt and rebolt the headbolts if doing the one by one method?
I was advised to do them via the most opposite bolts so as never to have 2 bolts on one cylinder loose.
Old Jan 12, 2020 | 10:25 PM
  #217
Rovel's Avatar
2007 E63 Amg
My plan is to get the head bolts replaced one at a time. I am trying to buy all the parts my mechanic will need.
After looking at the parts list I see that I might need 4 of Actuator Bolts - 910105-012018 and 8 of Timing Case Bolts - 000000001150. Can someone please explain what actuator and timing case bolts are? Does timing case mean valve cover? What is an actuator? Do I need these bolts if I am not pulling the heads off?
Old Jan 13, 2020 | 09:01 PM
  #218
Rovel's Avatar
2007 E63 Amg
Nobody knows what those bolts are for?
Old Jan 14, 2020 | 02:37 AM
  #219
Nate GZ's Avatar
2010 c63 AMG
Actuator bolts.. 🤙🏽
(which bolts down the actuator in front of the camshaft adjuster)
Old Jan 14, 2020 | 09:34 AM
  #220
Rovel's Avatar
2007 E63 Amg
Originally Posted by Nate GZ
Actuator bolts.. 🤙🏽
Thank you a ton!
Old Jan 14, 2020 | 11:21 AM
  #221
Nate GZ's Avatar
2010 c63 AMG
4sho!! I haven’t had a chance to experience the timing bolts yet. I’ve only went as far as camshafts/adjusters/lifters.
sorry 😣
Old Jan 14, 2020 | 11:28 AM
  #222
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
They're probably talking about the CA cover bolts. I believe they're the same as the timing cover.
Old Jan 14, 2020 | 11:34 AM
  #223
Nate GZ's Avatar
2010 c63 AMG
hey J. Quick question, are you familiar with the “p0012” code? I have the rattle on startup from CA.. CEL, and idle/shifts are crappy.
any thoughts?
Old Jan 14, 2020 | 11:55 AM
  #224
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
any thoughts?
Did you torque the CA bolt properly? Could be out of timing, faulty sensor, re-learn may be required.
Old Jan 14, 2020 | 12:23 PM
  #225
Nate GZ's Avatar
2010 c63 AMG
I’m more than positive that I torqued then all down equally. I can be wrong tho. I also replaced the cam position sensor. Might be even worse after the switch.
