C63 AMG (W204) 2008 - 2015
285/30-19 on rear 19x10 anyone?
Old Dec 19, 2015 | 04:59 PM
dlefty's Avatar
/////PRO
19x10" wheel
+50 offset
Anyone run or think that could get away with a 285/30-19 tire?
Stock suspension.
Old Dec 19, 2015 | 10:12 PM
AMGonFire's Avatar
2012 c63 AMG, 2011 GLK 350, 2019 GLS 450
Originally Posted by dlefty
19x10" wheel
+50 offset
Stock suspension.
Depends on the tire some run wider then others like the pss vs other tiresof the same size but you might still rub. 285 is pushing it maybe with a 53 or 54 offset.
Old Dec 20, 2015 | 12:40 AM
Phil Chow's Avatar
W204 C63
PSS won't work.
You might be able to get away with a Hankook Ventus V12, with a smidgeno f rear camber in the rear, and some trimming of the inner fender liner.
Also depends on how low you are. Stock height? Sure.
Old Dec 20, 2015 | 05:13 AM
Southways's Avatar
C63 Coupe, 2014, 507
Klassen M52R 19x10
Michelin PS-AS3
Note that this is on a 2014 Coupe, standard springs. No rubbing.
Old Dec 20, 2015 | 04:23 PM
AMG3.2's Avatar
C63 AMG, P30
Are those 285's though? That's quite a bit of a stretch. I'd venture to say those are 255's or 265's. ^^
Old Dec 20, 2015 | 04:35 PM
Southways's Avatar
As shown are 275's (only photo I have), but previously had 285's. I couldn't wait for another set of 285's to be imported to Au, so had to use the more readily available 275's.
Old Dec 20, 2015 | 05:47 PM
dlefty's Avatar
/////PRO
Good call, as I thought those looked just like my 275's.
I believe I have the room to the ooutside/exterior for a 285, but not positive/feeling good about clearance inside the wheel well area with suspension components and fuel filler neck.
Old Dec 21, 2015 | 01:03 AM
abcut973's Avatar
'12 C63 Black Series, '12 ML350 BlueTech
Lowered you will rub for sure.
OEM probably not. But then on aftermarket wheels it will look like a SUV
Old Mar 2, 2021 | 07:19 PM
Sb Singh's Avatar
c250
so will 285 work on a c250 sport stock suspension ?
Old Mar 2, 2021 | 08:55 PM
BLKROKT's Avatar
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
Nope
