C63 AMG (W204) 2008 - 2015
What rear toe setting are you guys using?
Old Feb 23, 2016 | 07:37 AM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
Originally Posted by QuartzBlueP31
Stock alignment 9500 miles on Hankook V12s 275/19
Right side
Left side
Right side
Right side
Originally Posted by QuartzBlueP31 Signature
ADV10 M V2 color matched Logos
EuroCharged V5
H&R Springs
AMG Door Lock Pins
Clear Corners
Godhand Carbon Fiber Front Lip
Custom CF Blue metallic interior trim
Stock alignment as in stock toe only since you're lowered. Your wear is completely normal for ~ 2° negative camber which it would be if you don't have after market camber bolts.
Old Feb 23, 2016 | 09:37 PM
roadtalontsi's Avatar
10 C six trizzle
tires that arent designed for a 4000lb car. how on earth did you get 9500 miles out of rear tires on a c63 lol.
Old Feb 24, 2016 | 11:03 PM
QuartzBlueP31's Avatar
2010 C63 P31
they have the same load rating as Michelin PSS and I dont do burn outs (that just wastes time)
Old Feb 25, 2016 | 07:58 AM
Mort's Avatar
But smokey fun tho...lol
Old Feb 26, 2016 | 08:26 AM
oggie's Avatar
2011 E550 4Matic & 2010 Audi Q5 & 2015 C63 507
I am about to install KW V3 in spring. I am going to keep the lowering to a minimum. Would I need camber bolts for the rear? Or I would need to purchase K-mac camber kit?
Old Feb 26, 2016 | 04:24 PM
Mort's Avatar
oggie there are no camber bolts available for the rear. If you want to adjust the rear camber K-MAC bushings are a great option. I just installed mine. Looking forward to spring as my car is on seasonal plates from April 1 to October 31 each year.
Old Feb 26, 2016 | 04:31 PM
  #32
oggie's Avatar
If I don't plan lowering the car too much, would I still run into issues with camber? Thanks Mort.
Old Feb 27, 2016 | 09:35 AM
  #33
Mort's Avatar
If you lower the rear about 20mm = .75" the camber will be about -2* to -2.25* . This is about the upper range of MB spec so it is not too extreme. If you lower it less the negative camber will be less. Either way it is not really a problem except that tire wear may go up a bit. The nice thing about the KW V3 is you can fine tune you ride height side to side to get the camber to come out equal side to side. The nice thing about the K-MAC camber bushings is now you have another point of adjustment to dial in the rear suspensions settings the way you want them.
