What rear toe setting are you guys using?
I don't want dial it all out to 0, as I've read a bit of rear toe in is helpful in a high hp rwd car...
There's a few threads about toe in settings, but no consensus that I could find.
I get my winter tires on and don't have the new tires yet - they had to order them from the warehouse, plus I want to repair some curb rash on my wheels. That's probably better timing with the spring weather anyways
After the drop it came out to 0.0* total front and rear. I did not bother trying to adjust the toe after the drop and decided to try the car out as it sat. The car drove fine all summer and I experienced no ill affects or handling issues from driving the car with these specs.
I can take some pics of my tires and some other c63's i've done the alignments on if you'd like.
Assuming zero toe, agree that negative camber will accelerate wear on the inside edge, because there is heavier load on the inside edge and that's what the tire is rolling on.
It seems like negative camber plus toe in would retain the higher load on the inner edge, and add scuffing (instead of just rolling, like a zero-toe tire would have). That seems likely to result in increased wear on the inner side of the tire.
