Foglight Bulbs (white LED version)
Looking to change the foglight bulbs to match the headlight white color. Does anyone know which ones are direct swap without having any CEL lights or issues? Thanks
Try AZN Optics he has LEDs that work. Mike is a sponsor here. You want 5000k wedge I think. Check with Mike and he will steer you straight.
http://www.aznoptics.com/
OK Mike covered it below for the fog lights. You can get Philips Diamond Vision H7 as a direct replacement for the '08-'11 PFL cars as well. I had a bit of a brain fart in my original post and was thinking of the side markers and not the fog lights. My apologies if I mislead anyone.
Last edited by Mort; 02-22-2016 at 10:14 AM. Reason: Side marker ligts v fog lights
For the cost of a good pair of LED foglights you could run a set of HIDs. I'm guessing you have a PreFL. I went back & forth from Diamond 5000k halogen, to LED to HID. Decided on HID for the increased light output. Will be ordering from theretrofitsource.com Its the H11a kit with the canbus relay. No errors. Very good quality products with great customer service.
SPONSOR/MBworld Guru
HID fogs are really the best way to go in terms of light output and spread. You'll want to stick with 35w kit though due to heat issues in the fog enclosure. We carry the same top end Morimoto HID conversion kits if interested
