What's the rationale from MB on tire sizing?
Does anyone know why the rear overall diameter is about 0.5" less than the front (based on the 19" wheels with 235/35/19 fronts and 255/30/19 rears)?
Why does this matter? What makes me you think it's odd?
Originally Posted by RW507
(Post 6765223)
Originally Posted by looney100
(Post 6766057)
Because a rear tire should NEVER be shorter than a front tire. They should always be equal or possibly a bit taller. These cars with stock tires look pathetic from the side IMO. |
I have wondered that too. BUT those German engineers must know something you don't when it comes to creating performance cars.
A lot of manufacturers do this actually.
BMW M135i, runs 225/40/18 Front and 245/35/18 Rear. Never understood it. But, in Asia actually, the C63s come with 225/35/19 and 255/30/19, so they match. Not sure why, who knows. |
Probably manufacturing cost savings. That tire may go on many other Benz vehicles so the get a good discount from the supplier and thought, that's close enough to go on a C63
Originally Posted by QWKSNKE
(Post 6766992)
(Post 6766992)
this is why I now a 275 with the stock profile out back. Tire fits much better on the wheel plus evens up the diamter between front and back
(Post 6766489)
Seriously?
Really you guys are concerned about the 0.5 difference in diameter?
I'm sure they are not using that tire size because the majority of their cars use them. I don't think a C250 uses the same set up. They spec the tires based on weight distribution and handling. for example the car's alignment and tire size combo is slightly setup towards under steering since it is easier to correct. If you change the tire size to achieve an even diameter between front and back then that would be just wrong. Besides that it looks like ass because your gap between fender and tire would be smaller in the back (unless adjusted with coil overs or spring pads) |
Originally Posted by Adam Lynagh
(Post 7495641)
you realize with 235/35/19 fronts and 255/30/19 rears, the rear tyre will have a slightly larger sidewall than the front. Dont you?
No it doesn't. The front does. Couple that with the ugly sidewall lean in due to a 255 not fitting a 9 in wheel properly the overhaul height is almost 1" shorter on the rear than the front. |
(Post 7495669)
Wow, thread resurrection...
(Post 7495690)
Sidewall height on fronts would be 82.25 mm and the rears side wall would be 89.25mm.. last time I checked 89 is more than 82)
