Found the problem
So I took apart my c63, thinking I have to replace the throttle body. I open up the intake manifold and find this!
I believe it's a piece of plastic from the airfilter? Took it out, put everything back together, car runs better than ever. https://cimg1.ibsrv.net/gimg/www.mbw...18595a566.jpeg |
Whooooaa!!! Holy crap! That's pretty crazy. Obviously it was keeping the throttle open slightly and getting in the way of it opening and closing. Glad it runs better now and problem solved!
Very strange. Someone last month posted the exact same thing. https://mbworld.org/forums/c63-amg-w...d-outcome.html
I'm opening up my intake manifold today for a little cleaning and the installation of phenolic spacers. Will report back if I find anything. |
Originally Posted by BLKROKT
(Post 6822852)
Also cleaned all the gunk out of the manifold and heads with some gasoline and a rag. Thinking that might have improved performance slightly!
Originally Posted by see_sicky_tree
(Post 6822801)
Originally Posted by need2speed
(Post 6822882)
Where is it from?
Wow, glad that did not make it past the throttle body into the intake runners. I know all engines are different. Does you car have a MAF sensor? If so where the hell was the screen at the sensor?
The carbon filters do have a plastic piece that looks like that on either end. Must have broken off when they were removed. If you have removed the carbon filters from the lattice work that holds them in the box top you would understand how it could happen.
The MAF sensor is inserted in the airway so that air flows over and under it. Entirely possible for that piece of plastic to be sucked into the intake past the MAF sensor. |
Wasn't 100% sure if they were from the carbon filters! They were off the car when I bought it!
Bringing up a slightly old thread. When you took the intake mani apart, other than the gasket that goes from the heads to the intake mani, was there any other gasket? I can't seem to find anything. I thought I remembered seeing at least one. If so, does anyone have a part number or a link? Thanks.
I believe the only gasket was the one for the heads to the manifold. Alsogonna want to replace the aluminum bolts that hold the intake manifold to the heads. If you are going to take the intake manifold apart, there a couple more of those bolts.
Originally Posted by chrisridebike8
(Post 7168391)
(Post 7168427)
Im 99% sure they're the same ones. Its been too long lol
(Post 7168464)
Thanks man. And just to clarify, the intake mani is kind of like a clam shell. It's held together with the same type of bolts as the TTY ones for mounting the intake mani to the heads? Or are they a different part number. I've have the manifold off for gasket replacement once before but I didn't take it apart and clean inside.
(Post 7168391)
(Post 7168464)
Part number for the little bolts is: MA009 990 30 04 - very expensive for what they are. Probably around $6USD each and there's 13 of em. You may also find Renntechs how-to useful for reference when torquing it back up again :y http://www.renntechmercedes.com/inde...t-instructions |
When I pulled my manifold to clean it last year I could NOT for the life of me get it to come apart(clamshell)....came off engine no problem, bolts for clamshell design came out no problem, but would not budge as far as separation goes
