C63 AMG (W204) 2008 - 2015
Check out my new CAI
Old Sep 1, 2016 | 08:19 PM
mr747's Avatar
c63
Been busy getting these bad boys ready for tuning
Just need to make up some air deflectors
Ill be taking off the CF ram intake and making something else
I will post more pics soon
Old Sep 1, 2016 | 08:47 PM
BLKROKT's Avatar
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
I like it man. Do you take the headlights out while drag racing? Just wondering how the filters are getting cold air - is there ducting under there? And where are the MAF sensors plumbed in, can't see em.
Looks like what the E55 guys do:
Old Sep 1, 2016 | 08:54 PM
mr747's Avatar
c63
maf sensors will be plumbed in on monday
Im in the process of making Something to direct air in but i think for drag racing i will take the head light out
Does anyone know where i can get custom headlights made with a hole in them?
Old Sep 1, 2016 | 08:58 PM
BLKROKT's Avatar
Old Sep 1, 2016 | 09:03 PM
mr747's Avatar
c63
hahahhahahah lol i might try something else first before i take this step
Old Sep 1, 2016 | 09:05 PM
BLKROKT's Avatar
Definitely make sure you get some flame retardant pipe insulation for those also. Or wrap them with that kevlar thermal headers wrap stuff. While it looks pretty, they're going to heat up pretty quickly if left bare like that.
Good stuff mate
Old Sep 1, 2016 | 09:06 PM
mr747's Avatar
c63
Maf sensor ****
Attached Thumbnails Check out my new CAI-mafsensor-3.jpg   Check out my new CAI-maf-sensor2.jpg
Old Sep 1, 2016 | 09:07 PM
mr747's Avatar
c63
Good stuff mate
i might ceramic coat the pipes
Old Sep 1, 2016 | 09:09 PM
BLKROKT's Avatar
This
Old Sep 1, 2016 | 09:52 PM
Merc63's Avatar
C63 AMG
Without air ducts you're going to suck lots of hot engine air
Old Sep 1, 2016 | 09:54 PM
CarHopper's Avatar
E63S | X5
You should add a spacer too between the filters
Old Sep 1, 2016 | 09:56 PM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
Yup, some sort of heat wrap and redirection of the inlet ports will be crucial. If not, that metal pipe directly over the headers will end up being a hot air intake instead.
The whole point of the OEM plastic is to help isolate heat since plastic is a poor thermal conductor.
You're gonna dyno the b¡tch right? Curious to see the results.
Edit: Did you have to relocate the catch can?
Old Sep 1, 2016 | 10:06 PM
mr747's Avatar
c63
air ducts will be run and also air deflectors
this cai will need to be tuned for which is happening next week
also headers are ceramic coated no issues with heat there will be fixed
but yes i agree it will suck alot of hot air if there are no inlet ports or deflectors
Old Sep 2, 2016 | 04:57 AM
Celicasaur's Avatar
W212 - E63 AMG
Interesting...
My experience on intakes (from cars down the years)
  • CAI"s are cool, assuming you can get the filter element right out of the engine bay and away from the radiator fans
  • You should see a good few degree's centigrade lower air temps if done right (which will help loads on your supercharged motor)
  • A bigger filter surface area will help (but usually space and fitment prohibits this)
  • An in-built velocity stack to the filter is also beneficial
Good luck and keep us posted!
