C63 AMG (W204) 2008 - 2015
Metal Rear Fenders
Old May 12, 2017 | 04:53 PM
  #51
BLKROKT's Avatar
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
That looks great man. I think you probably got 1/4" more out of them than I did. Same subtle look, wait until it's painted you'll love it. What tire back there, 305?
Nevermind, I see 295. I bet you could get a 305 back there.
On the front, left/right tire looks different. Have you considered a 255 there? Then you wouldn't have to mess with the front fenders, which are perfectly matched to the rears right now IMO. Any bigger might look lopsided or disproportionate again. The 265 seems to be bulging quite a bit anyway. Just a thought.
Your front offset might be the main issue actually because I know I can get a 255 under mine easy, and maybe 265.
Old May 12, 2017 | 05:13 PM
  #52
Mag1c Carp3t's Avatar
2009 C63 AMG
Yeah the offset is aggressive. I'm currently running toyos r888 so my option is either 245/35 or 265/30. I don't like the bulge either but I really don't have a choice. The tires are the same both sides. The driver side fender was rolled and pulled which is why it might seem different.
Even when I had 235/35 it would rub a little. So anything bigger fender work is required.
Old May 12, 2017 | 05:16 PM
  #53
BLKROKT's Avatar
Oh yeah, nice I see it now. Honestly I think you're better off just mildly rolling/pulling the other fender like the drivers side once it's repaired if that's all it needs to fit. IMO it's perfect like that, and you're not going to get as much utility and looks from going ***** out on the front like the rears.
Old May 12, 2017 | 05:58 PM
  #54
2009 C63 AMG
Unfortunately since the aluminum is so thin it'll crack again at the joint when trying to roll and pull again.
Old May 12, 2017 | 06:46 PM
  #55
BLKROKT's Avatar
Ugh sorry to hear. Well it'll look dope when done, can't wait to see the finished product.
Old May 12, 2017 | 10:26 PM
  #56
2009 C63 AMG
Talk about some quick progress.
Old May 12, 2017 | 10:31 PM
  #57
BLKROKT's Avatar
That's gonna look BANANAS
Old May 12, 2017 | 10:35 PM
  #58
BadCompany's Avatar
2014 C63 AMG Edition 507 coupe
Awesome!
Old May 15, 2017 | 10:01 PM
  #59
2009 C63 AMG
Latest Progress. There will be a little peice that'll go on the front bumper to make it flush.
Old May 16, 2017 | 04:17 PM
  #60
Kriston's Avatar
C63 AMG
Damn the setup looks meaty!
Old May 16, 2017 | 05:46 PM
  #61
2009 C63 AMG
yeah man. Wish I had taken a video when he was rolling the car out. A little turn on the steering wheel would show half the tire.
Old May 16, 2017 | 09:09 PM
  #62
Schulminator's Avatar
2015 C63s Sedan
Man, that looks great!! Can't wait to see the final outcome with the exterior and engine mods
Old May 17, 2017 | 06:44 PM
  #63
2009 C63 AMG
Car is done. Got the other side welded up and took it for a spin. The inner tire is rubbing the strut. So I have to go 245/35 now.
Old May 17, 2017 | 07:11 PM
  #64
BLKROKT's Avatar
You're going the wrong direction with your tire man! What about a 5mm spacer and some more neg camber?
Old May 17, 2017 | 07:34 PM
  #65
2009 C63 AMG
Camber works a little differently on this car. More negative camber pushes the whole wheel out from the bottom. I had camber bolts installed and had them make it positive as possible and it pushed the wheel in quite a bit but it's at the max. I can try maybe a 3mm for now. Or I can look into upgrading my top hats to KWs camber plates if that's possible.
Old May 17, 2017 | 07:43 PM
  #66
BLKROKT's Avatar
I was thinking that the neg camber would allow you to run a spacer to get clearance to your strut and still tuck the wheel under the fender.
Old May 17, 2017 | 07:45 PM
  #67
2009 C63 AMG
Can I just run their camber plate since I only need to move the top of the wheel inwards.
Old May 17, 2017 | 07:46 PM
  #68
BLKROKT's Avatar
That would do it. KMAC one is great. Not sure you can get the KW one separate from the Clubsports.
Old May 17, 2017 | 07:56 PM
  #69
2009 C63 AMG
This is actually a brilliant idea. Once these tires have worn out I'll go down to a 245/35 remove the spacer and adjust both the lower control arm and the top hat to push the whole wheel back out.
Old May 17, 2017 | 09:29 PM
  #70
julours's Avatar
C63 AMG w204
This looks really great with wide fenders like that, I like it.
What will be your solution for the front bumper to adjust to wider fender?
And I'm surprised about your decision to go back to 245 tire, as this is the front tire size I have with original fender size and there is no rubbing.
Old May 17, 2017 | 09:33 PM
  #71
2009 C63 AMG
Keep in mind I'm running KW V3 coilovers though. So the rubbing im experiencing is the inner tire of the 265/30 on those front struts. The welder made a metal template for the body shop to make a mold of and attach to the front bumper.
Old May 17, 2017 | 10:01 PM
  #72
julours's Avatar
C63 AMG w204
Ok thanks for the input, I'll look for that clearance as i'm also looking to go with KW V3DDC or Clubsport
Old May 17, 2017 | 10:05 PM
  #73
BLKROKT's Avatar
You'll need about 7mm extra clearance going to the Clubsports. My 255's fit fine on OE suspension, and now I'm on 10mm spacers in front. OP is having the same issue on top of his aggressive offset.
Old May 18, 2017 | 11:13 PM
  #74
2009 C63 AMG
Just placed an order with Kevin@K-Mac.
Top camber plate
Front camber bushing
Rear toe and camber bushings.
4pc solid bushings for the thrust arm
Combined with my rear upper camber arm I should now be able to move both the front and rear wheel in and out as I see needed. In short I can customize my own wheels offsets now.
Old May 19, 2017 | 08:41 AM
  #75
Mort's Avatar
Very nice to have that adjustability in your suspension. I have K-Mac rear camber and toe bushings as well as front top plates and camber and caster bushings (not installed yet) for the front. Kevin is a great guy to deal with as well. Let us know how the rear thrust arm bushings go. I might do those next winter.
