Mbh header mid pipe install
Purchased a set of mbh headers and catless mid pipes had them installed and dyno tuned having a problem with vibrating noise under car my question is do I have to remove the cross bar in middle of car the pipes seem really tight in there ,only rattles when I put car in gear with foot on brake never did it before pipes were installed
You can remove that cross brace, use spacers (or many washers) to get clearance, or MBH makes a modified crossbar that clears the pipes. I opted for spacing it with washers, although I ran the car without the brace for a few months with no ill effects so you could prob just remove it.
Originally Posted by BLKROKT
(Post 6965261)
Remove the bar
Correct, I used some SS washers to space the crossbar down. Once it warmed up the mids touched slightly.
Originally Posted by Schulminator
(Post 6965347)
I haven't noticed that bad of smell, but I think my Remus system might help a bit... it sure tones it down.... but man the cold starts are nice in my garage. What were your #'s on the dyno?
(Post 6965486)
Originally Posted by beaststunt
(Post 6965503)
https://cimg1.ibsrv.net/gimg/www.mbw...70a60f4b19.jpgNot sure if pic is any good but dyno before header install was 416 whp 373 torque row boxes ,tune ,res delete sec cat delete ,with the headers installed went to 445 whp 414 torque gained 29 hp and 41 torque
(Post 6965486)
https://cimg7.ibsrv.net/gimg/www.mbw...e0e0a44335.jpgJust a pic before install
Originally Posted by chrisridebike8
(Post 6965506)
Do you have any videos of your setup? I wish there was a little less rasp on my catless ARH/stock muffler setup. I haven't seen any headers/Remus videos.
(Post 6965506)
Thats some crazy torque gains!
Gain all across the graph. Headers are def my next mod
