New member and needs help upgrading wheels
2013 C63 Amg coupe
Just go my first 2014 c63 ! Equipped with Tire Pressure Loss Warner planning to upgrade my wheel from OEM 18" to 19". Will i get any warning message? Will the system detect a difference from 18" to 19" wheel thus it will display warning. I hope it doesn't work like a TPMS.
TIA
TIA
TIA
TIA
2013 C63 Amg coupe
If your car does not have TPMS sensors in the wheels then you have the Tire Pressure Loss Warning System. This system works with the ABS System and monitors the rotational speed of the wheels. Once you install your new wheels and set the tire pressures you may need to restart the system through the steering wheel controlled menu.
TIA
TIA
19" wheels and tires are pretty much the same diameter so no worries.
