C63 AMG (W204) 2008 - 2015
Seats Lumbar problem again
Old Mar 25, 2017 | 11:28 AM
kepsus's Avatar
C63 Compressor
Hey this is my first post here, I own a c63 2009 with some Kleemann option (compressor , long headers and so on) but thats another story.
I have search to the end of internet :-D , about the lumbar support dosent work on front and passager seats. What i find is the 5 amp fuse has gone, or they have put it to MB to get it fix..
I have check and changed the fuse, but with no luck. Anyone know what to look for.
Old Mar 25, 2017 | 11:56 AM
roadkillrob's Avatar
Top Answer: 1
12 C63BS Magno Alanite Grey, 25 X5 Msport, 08 BMW E93, Ducati Hyper 698
I think if you search around there is a thread about the wires in the seat getting pinched and that results in the blown fuse but replacing the fuse will just blow again.
Mort's Avatar
Check the wires in the seat. They are prone to wear from movement. Going from memory but I think that is what causes the lumbar supports to stop working.
roadkillrob you beat me to it...lol
Old Mar 25, 2017 | 11:57 AM
Top Answer: 1
try this also https://mbworld.org/forums/c63-amg-w...seat-fuse.html
saw this also
I had this exact same issue on a 2010 sedan. The fuse will blow next time you change the position of the seat/backrest. The wiring for the lumbar support/side bolster etc runs across the hinge section of the seat and depending on the position of the seat will over time wear through the insulation and short out. I had it fixed under warranty - was a "seat out"/2 day job to fix. So if you still under warranty get it sorted now, otherwise don't touch the position of the seat/backrest and you should be fine.
Old Mar 25, 2017 | 12:00 PM
BLKROKT's Avatar
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
Search: lumbar wires
Try this one: https://mbworld.org/forums/c63-amg-w...t=Lumbar+wires
Old Mar 25, 2017 | 01:16 PM
kepsus's Avatar
C63 Compressor
Thanks, but it dosent blow any fuse, been trying like a maniac to look at wire and cant see any they are cut.
I see they also say it could be relay, can any tell me what relay and where it is lcoated
