C63 AMG (W204) 2008 - 2015
Fuse 56 Keeps blowing out " Seat/Bolster "
Old Apr 20, 2017 | 06:51 PM
Black_Mercedes's Avatar
C63 P31, C320
2011 c63 p31
So for some reason the Bolstering in my car keeps blowing fuse 56 in the trunk of the car.
Im not sure if its driver seat or passenger seat that's doing it. Some days it will be good for a couple of days some times it blows as soon as i put the fuse in.
Does anyone have a wiring diagram or some information on whats causing it?
I looked it up and some people said the wiring in the driver seat becomes frail?
I also noticed somedays it says my right licenses plate light is out i have to go outside the car and tap on it pretty ghetto for it to turn on. Not sure if that has anything to do with that line on fuse 56.
Old Apr 21, 2017 | 01:44 PM
Adi-Benz's Avatar
2010 C300 4MATIC........ 2011 C63 AMG.............. 2015 CLS400 4MATIC.....
Lol @ ghetto
Did you check the connections?
Old Apr 21, 2017 | 05:13 PM
C63 P31, C320
I will post vin number as soon as i get home from work. Thanks
Yeah i pulled off the back cover cleaned everything up it worked.
Then i closed the trunk and the error popped back up. Had to go back out and flick it LOL
Old Apr 21, 2017 | 05:30 PM
C63 P31, C320
Vin WDDGF7HB9BF569057
Old Apr 23, 2017 | 01:51 AM
DAMG63's Avatar
w211 E55, w213 E63s
Had the same issue with mine. Took into dealer (under factory warranty still). They started off by replacing fuse as well. Went out within 5 minutes. Traced a short back to drivers bolster motor. Replaced both bolster motors in driver/passenger seat. Issue gone. Hope this helps!
Old Apr 23, 2017 | 11:19 AM
C63 P31, C320
All the motors work it seems to happen when i move the passenger seat forward or backwards.
Old Apr 23, 2017 | 11:45 AM
DAMG63's Avatar
w211 E55, w213 E63s
I would bet theres a short or a wire might be getting pinched.
Old Apr 23, 2017 | 02:33 PM
C63 P31, C320
anybody have a wiring diagram for the seats? Wondering if i should take them out and have a look or just forget about it
Old Apr 24, 2017 | 07:56 PM
JimmyR's Avatar
E63S
Happened on my pre FL. There is a wiring harness that depending on position the power seat is set to gets kinked/pinched near the "hinge" of the seat. Eventually wears thru the wiring insulation, creating a short and blowing the fuse. I had this fixed under warranty, was told it was a "seat out, half day" job.
Old Apr 24, 2017 | 08:13 PM
JimGnitecki's Avatar
2012 Mercedes C63 AMG S
I can see why this would happen, especially if you often carry a rear seat passenger, as the passenger side front seat move forward and backward TWICE for each ride (when the rear seat passenger enters and when he/she exits). Given enough time, the wiring insulation WILL wear through.
This could be either a design or assembly error.
Make me think about proactively finding the offending wireset and wrapping it in a wiring protector split-tube before MINE fails, as our adult son lives with us and is a frequent rear seat passenger.
Anybody got a picture of the wiring location?
Jim G
Old Apr 24, 2017 | 08:24 PM
ZephyrAMG's Avatar
2010 Irridium Silver MB C63 AMG Sedan
Thank you as I have been trying to figure this out...
Both my front seats don't work for lumbar support...
Old Apr 25, 2017 | 09:44 AM
C63 P31, C320
Any body have a diagram showing which of the wiring goes bad on the seats? Im thinking about taking it out over this next weekend when i have time. I had to buy a box of fuses at harbor freight lol
Old Apr 25, 2017 | 11:25 AM
KGc63's Avatar
MB: 2012 C63, 1986 300e, VW: 2013 Tuareg TDI, 2002 GTI
Both seats run off the same fuse. I had this issue when I first got mine a few months ago. After temporarily adding individual fuses for each seat to diagnose, the shop cut out and spliced in a section of the harness that powers the bolsters.
Old Apr 25, 2017 | 11:26 AM
ZephyrAMG's Avatar
I would also appreciate some pics or a diagram. Very odd for the lumbar support to keep blowing...
Old Apr 25, 2017 | 11:31 AM
C63 P31, C320
I didn't figure to test it before i picked up my car lol. Now its gonna bug the **** out of me.
Old Apr 27, 2017 | 01:16 PM
masonpardo's Avatar
2008 C63 AMG
Might be totally useless but I had fuses that kept blowing because I had coins in my cigarette lighter.
