C63 AMG (W204) 2008 - 2015
BBS LM-R fitment
Old 05-02-2017, 02:26 PM
kazabu's Avatar
Mercedes C63, Ford mustang gt
BBS LM-R fitment
Does anyone knows if bbs lm-r will fit on our c63 w204 without rubbing? front 255/35/19 8.5 ET35
rear 285/30/19 9.5 ET 40
BBS LM-R
Old 05-02-2017, 03:09 PM
Kriston's Avatar
C63 AMG
Front will not clear with 255 wide tires. need 235 wide and you should be okay. Rear you will rub especially if lowered.
Old 05-02-2017, 04:32 PM
kazabu's Avatar
kinda figured it wouldn't fit. So unfortunate. Thanks for your help though
Old 05-03-2017, 08:51 AM
arrowskartax9's Avatar
C63 AMG
I went from a 235/35 19 to a 245/35 19 front on my car. Should fit yours aswell.
Old 05-03-2017, 08:53 AM
C63 AMG
I also went with a 265/30 19 0n the rear.
Old 05-03-2017, 07:10 PM
Diabolis's Avatar
W204 C63 Coupe, W166 ML350 BlueTEC, 928GT, C5 Z06 & IS300 race cars, EQE 4Matic+ on order
While a 245/35-19 tire mounted on a 8.5" ET35 rim will fit without rubbing from a fender clearance perspective, the spokes on that particular rim might not clear the front brake calipers on the C63. I wanted to use my RS-GTs from my Audi on the Merc as winters (same width & offset as the fronts the OP is asking about) and couldn't mount them.
Quick Reply: BBS LM-R fitment
