FS: KW V3 Dynamic Damping Control (DDC) coilovers
x KW V3 Dynamic Damping Control (DDC) coilovers
KW V3 DDC coilovers with ECU option of using KW's App control + individual set ups in a push of a button. The KW DDC coilovers are part of the KW iSuspension program - the intelligent suspension solution for vehicles without factory adaptive suspension. These combine the advantages of an adaptive damping system with a vehicle-specific aftermarket suspension solution. Lowering can be done via the composite spring collar on the shock body or on the height adjustable rear perch in the rear of the vehicle. -dirt-resistant trapezoid thread and the composite collar -retrofit electronic damper adjustment -3 damping setups: Comfort / Sport / Sport+ -operation by retrofit button and/or optional App -create personalized setups with the KW DDC App The coilovers with this electronically controlled dampers enable an intelligent suspension setup via App-control. This allows you to upgrade your car with an adaptive damper control, and to have the option to adjust via the KW DDC App to suit your driving style. You do not need any tools to physically adjust the dampers! The free KW DDC KW App in combination with our optional W-LAN module allows you to customize your own damper setup instantaneously. This is an amazing coilovers set for our cars for both use on the roads and at the track. Price: $4,650 CAD ($3,478 USD as of March 26th exchange rate) + shipping PMs welcomed. https://cimg8.ibsrv.net/gimg/www.mbw...5e165ec38a.jpg https://cimg6.ibsrv.net/gimg/www.mbw...aae99ede37.jpg https://cimg7.ibsrv.net/gimg/www.mbw...cd361d704a.jpg https://cimg0.ibsrv.net/gimg/www.mbw...6cf78cab77.jpg |
I hate to break it to you, but a brand new set including shipping can be purchased for us$ 3900.
Originally Posted by sventastic82
(Post 7135679)
Reasonable offers are more than welcome and will be considered then. |
BUMP!
