Brake squeak only during light braking to a stop??
My C63 brakes seem to be "squeaking", but ONLY when braking very lightly and coming to a stop. The noise disappeared briefly after I washed the car, but returned a couple of days later.
Is this dirt on the pads or rotor, or ?
Jim G
Jim G
It's inherent of more aggressive/harder compound pads. When the brakes are cold, they'll squeal. Try heating em up then try the light braking again. I can almost guarantee it won't be there... Temporarily
It was suggested some more aggressive braking at speed occasionally will clean them up.
Since he told me this I will get up to 115 kph, keep the speed up with my right foot and drag the brakes for about 200 m and so far OK.
AMG3.2 (07-28-2017)
Jon M who you know tells me they find the pads tend to glaze from stop and go driving at low speeds assuming you have sufficient pad left.
Jim G
Received 2,810 Likes
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
Or do a handful of hard stops (80-20mph, hard, but not so hard as to cause ABS to kick in) in a row to get them hot, then drive 20min without braking to cool them off, that should do it. Like a mini bedding process.
Alex.currie44 (07-28-2017)
TC
Jim G
I seem to have this noise too, but I'm not too concerned.
More importantly, I get light steering vibration when braking normally at higher speeds. Is this indicative of low pad thickness?
Edit: Vehicle front pads had 4-5mm about 2 months ago. Rear pads had 6.5mm, so I dont think it's because of thin pads. Do I need wheel balancing?
But I have no MB prior history to compare it to. My own C63 does not exhibit any steering wheel vibration on brake application at any speed.
Jim G
I want to see a show down between the Poerterfield RS4's and the Powerstop Z23 carbon/ceramic. No Bull**** I would love to see a side by side comparison of the two and see how they perform. Darryl its too bad you live 5000 miles away from me we could set up a course and do some real testing.
Ive used the Porterfield a couple times now, with good success.
Ergo Im willing to spend a couple hundred bucks to go with what I know works, from the first day to the last day, especially since my kids ride in the car. I don't experiment with safety equipment.
Thats not to say I think you are at risk, but as you know I blow money in all kinds of ridiculous ways lol. I can come up with a couple hundred for this. Ill scrimp somewhere else.
I think the concern there would be doing it over and over and over and over again. Longevity. And performance degradation.
For those of you even remotely interested I found that the Bondurant race team is sponsored by powerstop brakes and use them in all their cars.
https://bondurant.com/powerhouses-speed-safety-join/
That's like saying if the food doesn't give you diarrhea, that's a win for that restaurant and you'd recommend it to friends.
There's more to brakes than one-time stop distance.
BLKROKT (07-28-2017)
I don't know how you figure thousands of dollars? Porterfield about 350 bucks stock pads are about 800 bucks and if you already home them it wouldn't cost you anything. Powerstop is made by Centric a pretty well-known brand and use exclusively by Bondurant race team.
Your hypothesis is that your brakes are better simply because they cost more I say prove it let's do some testing and let the results speak for themselves.
My hypothesis isn't that the trusted brands are better because they cost more. My hypothesis is that the trusted brands cost more because they have real experience behind them in designing and building brake pads for the luxury sports sedan market, which the $50 manufacturer lacks.
I see it like a David and Goliath type of thing.. we know the porterfield are good but I see the Powerstop as the underdog who given a shot might be able to hold his own with the champ. Lets say we did some tests with the Porterfields from 60-0 and 100-0 and measured the distance. If the powerstop were within 10% of the Porterfields I would concider that a win.. if they matched them or even beat them it would be a grandslam. I am genuinely curious.
And I Brett Farve does those copperfit commercials on TV. Are you runnning out to buy that **** too because of its magical healing properties? Do you believe everything you see on TV?
That's a stupid comment David and Goliath blah blah. Do that with carbon bling, not with brakes. Seriously, no really seriously did you ride the short bus to school as a kid? I can't believe you actually think it's a good idea so "test" "underdog" brake pads.
Your only basis for not liking them is they are not $500 a set. You have no evidence and are not willing to even test a set to prove they are not up to par. You have no scientific evidence to support your claim.
The copperfit reference is actually funny because I play golf with a guy who has pretty much everything they sell and I make fun of him every time we play because he thinks it helps him..
