C63 AMG (W204) 2008 - 2015
Exhaust vibration after straight piping secondary cat
Old 08-04-2017, 02:49 PM
bullitt69's Avatar
c63 amg PP (w204)
After straight piping my secondary cats the exhaust system starts vibrating/resonating a bit at precisely 1000-1200 rpm (even when revving while standing still).
The vibration can be felt through the steering wheel.
I had my car lifted up and the tech inspected the car while I was revving. he said that by removing the secondary cat I took weight off the section which causes resonance in the pipes.
Now I kind of feel sorry for cutting off the secondary cat section.
Did anyone have this problem with this mod? Maybe any ideas?
Old 08-04-2017, 03:04 PM
NotABaller's Avatar
2012 C63, 2014 E550
This definitely isnt normal. Does it only vibrate when revving still? or while driving too?
Old 08-04-2017, 03:10 PM
bullitt69's Avatar
c63 amg PP (w204)
yes, when driving as well. But only in the mentioned rpm range
Old 08-04-2017, 03:15 PM
mrmotoguzzi00's Avatar
16 E550 Cab, 2003 Ram bright red crewcab 4x4 we call Clifford :)
is it rubbing or close to anything ? most likely your not gonna feel that unless it's touching something....
Old 08-04-2017, 03:16 PM
bullitt69's Avatar
c63 amg PP (w204)
I had that checked, no rubbing!
Old 08-04-2017, 03:18 PM
NotABaller's Avatar
2012 C63, 2014 E550
So the mechanic cut off the cats, and then welded two straight pipes, and now your steering wheel vibrates at 1k-1.5k on all gears, regardless if stationary or moving.
Were you there when the work was done? Is something touching the metal brace that joins the two undersides?
Old 08-04-2017, 03:19 PM
any of the rubber muffler hangers worn out ? cracked ? missing ?
Did the exhaust manifold bolts or downpipe bolts get checked ? those can certainly loosen or break if they are moving pipes around to weld....
Old 08-04-2017, 04:04 PM
bullitt69's Avatar
c63 amg PP (w204)
yep, I was there. Actually the exhaust was touching the steel bar but I had that redone. Now they are no rubbing issues, only this freakin vibration
Old 08-04-2017, 04:07 PM
bullitt69's Avatar
c63 amg PP (w204)
the rubber components were checked and they seem ok. The manifold bolts were not inspected today, but I was told that the exhaust vibrates after the primary cats which makes me think that the exhaust section closer to the manifold is secure.
Old 08-04-2017, 05:09 PM
Mort's Avatar
Sounds to me like your pipes are hitting the cross support when the car is running. Maybe not when it is off and you look at it on the hoist. Did they put a good bend in the pipes just before they bolt up to the resonator? If not that is your problem. No on else reports vibration issues especially ones you can feel through the steering wheel. That is the only problem I have heard of so far.
Old 08-04-2017, 06:31 PM
PJmak's Avatar
Does the engine shake? Look under your hood
Might be something causing the engine to run rough after the mod??
Old 08-04-2017, 07:00 PM
roadkillrob's Avatar
12 C63BS Magno Alanite Grey, 22 X3M Brooklyn Grey, 08 BMW E93, 22 Ducati Desert Sled, John Deere 3R
I have Mikes power pipe in no secondary cat and smooth as butter no vibration, sounds like it is touching something - maybe the pipes he put in were a bit short or long and moved the rest of the exhaust around and it is hitting somewhere else, closer to the motor or the back. Steering wheel vibration would indicate something is touching a steering component or something a steering component is attached to.
Old 08-04-2017, 11:01 PM
Mikegpr03's Avatar
C63
Call me OCD but I check all against the jig we had fabbed up so the angles and flow is improved yet nothing touches.
Old 08-05-2017, 03:37 AM
bullitt69's Avatar
c63 amg PP (w204)
I noticed that all your pipes are somehow interconnected. There is either the H pipe or a supporting bar. Mine aren't. Can this be the reason for the increased resonance?
Old 08-05-2017, 05:05 AM
Savage-wp's Avatar
2014 Mercedes C63 AMG 507 Edition
It must be touching somewhere. Does it do it when the engine is cold? Or only when hot. The exhaust gets longer as it gets hotter. So it may not be touching anywhere when it's cold.
Old 08-05-2017, 10:12 AM
Mikegpr03's Avatar
C63
Yes it plays a role lots of obsessing over small details and pissing off the fabricator until it was perfect in
every way.
Old 08-07-2017, 09:01 AM
bullitt69's Avatar
c63 amg PP (w204)
I had the car checked again yesterday - the vibration is coming from the engine, that is why the exhaust is vibrating.
I'm getting no CELs, the vibration occurs only in the 1000-1300 rpm range in all condions (cold/hot engine, stationary/moving/on the lift). The vibration isn't massive, more like a drone which can be heard, felt both in the steering wheel and pedals.
I'm scheduled for an oil service (sevice A) to an MB dealer in 2 weeks. I'll make them look deeper into the problem. All previous inspections were made at a regular auto service shop.
Maybe something is wrong with one of the injectors or harmonic balancer.
Any advice regarding engine vibration issues withou CELs in the low rpm range is very welcome.
Old 08-07-2017, 09:05 AM
bullitt69's Avatar
c63 amg PP (w204)
Another issue I'm having is humming/droning sound on over-runs. I can't figure out whether it's coming from the engine/tranny area or from the exhaust as a result of the deleted secondary cats
Old 08-07-2017, 09:30 AM
does it do it in neutral or only in gear, could be a driveline vibration it it only occurs in gear.
Old 08-07-2017, 09:32 AM
bullitt69's Avatar
c63 amg PP (w204)
The vibration occurs both in neutral and in gear. It seems to be only RPM dependant
Old 08-07-2017, 09:42 AM
BLKROKT's Avatar
Received 2,810 Likes on 1,664 Posts
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
Motor mounts
Old 08-07-2017, 09:50 AM
bullitt69's Avatar
c63 amg PP (w204)
Originally Posted by BLKROKT
Motor mounts
Both engine mounts and the tranny mount were replaced 2 months ago
Old 08-07-2017, 10:44 AM
PJmak's Avatar
02 sensors
Old 08-07-2017, 10:48 AM
bullitt69's Avatar
c63 amg PP (w204)
Originally Posted by PJmak
02 sensors
They were unplugged two times: once when I had the motor mounts replaced, and the second time when I had the secondaries deleted. You think they could have been mismatched? I believe it would have caused I cell due to incorrect values.
Old 08-07-2017, 11:23 AM
PJmak's Avatar
My car had an odd vibration in drive inidle.
I had a new maf, trans mount, and engine mounts are still solid.
The car would have a very slight vibration, kind of irregular tempo.
Replaced two 02 sensors that I could get to and its gone but its still there while in park. Kind of odd and not 100% sure thats your issue but its worth looking into.
All 02 sensors are different part numbers on my car(98 c43 amg), its probably the same with yours
Quick Reply: Exhaust vibration after straight piping secondary cat
