Windshield washer lags behind wipers
When I turn on the washer, the wipers take off immediately and the driver's side blade usually makes it all the way up to the A pillar before any liquid comes out of the squirter. Dry blades jumping and hopping across a dry windshield sounds like crap - not a class act. Is this normal? I don't recall it happening in the past. . .
Mine does the exact same thing. I very rarely use the windshield wiper fluid so it might because after a while the fluid in the lines drain out back into the tank? Not sure
Gonna test it with using the fluid twice on the same trip
2010 E350 Luxury Sedan, Engine 272 (V6)
One thing about blades is that many people don't clean them when they clean the windshield. I use the towel I clean the windshield with to wipe the blade. Pull the blade up and run the towel over it. Then wipe the windshield area under where the blades sit.
Mine behaves the same way. Then I try to time the next washer spray as the blades are traveling downwards, about 3/4 of the way across the windshield. Usually takes two tries to get it right 😊
