60 to 130mph testing
https://cimg9.ibsrv.net/gimg/www.mbw...79e87e262c.png 2012 c63 p31 sedan full interior and 93 oct pump gas lth xpipe n ap rear stage 3 Weistec 6.5sec with a 2.4 negative slope |
BEAST
What's your times on vbox 100kph to 200kph |
Originally Posted by Brunty88
(Post 7375380)
Originally Posted by gzim335
(Post 7375413)
not sure but it did 60 to 120 in 5.2 seconds don this run i use vbox to log mine although I only have ppp and exhaust work but you're pretty much 2 seconds faster 😮 |
(Post 7375415)
impressive what settings were you using for the run ? i use vbox to log mine although I only have ppp and exhaust work but you're pretty much 2 seconds faster 😮 |
Gzim, I am a fan. Damn that thing is moving!! :splooge:
(Post 7375415)
(Post 7375416)
i let the car do the shifting as manual mode is too inconsistent, so only s+ works |
Wow. That is FAST.
Try it in c I've tried c s s+ m short shift etc it was a while ago but I'm sure c was the quickest |
(Post 7376094)
(Post 7376094)
Originally Posted by MTV10
(Post 7375838)
What do you mean Manual mode is inconsistent? Easy to mis-shift?
(Post 7376191)
c will short shift so thats not possible,s+will always be faster unless you can nail all in manual ride before it hits limiter
if you ring it a few times in c it doesn't short shift massively well mine doesn't c may shift lower but you lose torque ringing it to redline in s + give it a go |
60-120 run did you start on third gear. if you did not then you still can go lower than that
keep it up |
