C63 AMG (W204) 2008 - 2015
East Coast Euro C63 Billet/Poly Engine and Transmission Mounts
Old Dec 23, 2018 | 07:56 AM
  #101
blackbenzz's Avatar
haters crazy
Originally Posted by Crya
Question about overall “lowering” effect. I saw Jim said about 6mm lower after install, which means everything is lower that hangs off the engine. Maybe a stupid question but I just got done installing the Ultra Racing cross brace and for whatever reason on the right side it makes the tiniest little kiss on the cat which is a stock cat, no headers. I’m going to see if it’s driveable
as such. Cold start transmitting all vibrations from cat to cross bar and to chassis like a tuning fork. Is it safe to assume that if I add the mounts, this is will exacerbate the clearance issue to the cross brace? Thanks. Just wanting to understand how mods may impact each other.
Cheers.
Excellent question. I'm not aware of anyone that has installed the mounts with the ultra racing cross brace. It would come down to how collapsed your current mounts are. If they are full new height (they usually aren't) and they are already touching then I wouldn't go shorter. If they are collapsed then new mounts would increase the gap.
Old Dec 23, 2018 | 09:06 AM
  #102
Crya's Avatar
2009 C63 P30
Ahhhh thanks. Got it. Maybe I’ve got a collapsing mount which explains the contact on that side. 70,000 mi and afaik, original mounts.
Old Dec 23, 2018 | 02:08 PM
  #103
BLKROKT's Avatar
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
The Ultra underbody braces are going to be fine. No rubbing here. My OE mounts were in good shape.
Sorry..... just re-reading your post. You said it’s already rubbing? This is all going to depend on the shape of your existing mounts. The ECE amounts lowered my engine ~6mm and my OEM mounts looked fine (I think Ahmad said to expect about a 10mm drop so that may mean that my OEM mounts were 4mm deflated already). If your OEM mounts are shot, and they may be since your cats are rubbing on the Ultra bar, then the ECE mounts may even raise your engine. Too many variables to guess which way it’s going to go for your car.
Old Dec 31, 2018 | 08:51 PM
  #104
Crya's Avatar
2009 C63 P30
Must be a right side mount going bad. I was able to find some adjustability in the bar and got it off the cat. See comparisons below. Drives great now. But under hard acceleration the mount must be moving enough to allow the cat to touch the bar given the small clearance because vibration returns. It’s my best laypersons assessment. So...I must need new mounts am I right?!?!
Left Side cat/bat clearance good.
Bar clearance
BaR clearance right
Yep, I'm the loser on MBWorld on NYE. HAPPY NEW YEAR!!!
Old Dec 31, 2018 | 10:44 PM
  #105
East Coast Euro's Avatar
Former Vendor of MBWorld
C63 and CLK55
It seems like your right side mount may have collapsed (maybe not fully yet). Happy New Year!
Old Mar 1, 2019 | 06:28 PM
  #106
everman's Avatar
00 S430
Do they fit 2013 W221 S550 Bi-turbo?
Old Mar 2, 2019 | 01:42 AM
  #107
ceesixthree's Avatar
2012 C63 AMG Coupe P31 Magnuson Super Charged
Was there an install thread? I lost it. Im going to do mine ive had for 6 months and report. They look sick bit of craftmanship.
Old Mar 2, 2019 | 08:44 AM
  #108
C63 and CLK55
We have not tested on that car.
Yes the install thread is here
https://mbworld.org/forums/c63-amg-w...oast-euro.html
Let me know if you have any questions. Thanks
Old Mar 3, 2019 | 06:05 PM
  #109
the_indian_kid's Avatar
2008 MB C350 4MATIC/2011 CL63 AMG/2014 C63 Coupe 507
Any made for the 2011 CL63 M157 Bi-turbo models also?
Old Mar 3, 2019 | 06:22 PM
  #110
C63 and CLK55
Yes we do have them available
Old Mar 24, 2019 | 10:32 PM
  #111
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
Old mounts were gross but only the pass side showed signs of leaking.
Was too much trouble to source the aftermarket tool here I so used a snap-on torque adaptor. https://store.snapon.com/Standard-mm...r-P770576.aspx
Not ideal but made it work. If i"E" was an inch longer it would have been perfect.
Old May 2, 2019 | 08:56 PM
  #112
Crya's Avatar
2009 C63 P30
BUY THESE AMOUNTS
Got my mounts installed today with the Track poly. JFC!! Wow. Huge difference. So both my mounts were in fact bad and had collapsed so that's why cats were hitting my Ultra Racing bar. Bonus, I now have massage seats. Car shakes and vibrates just at idle. Step on it and it's all good. I can't believe how much better my car is now with these in. Seriously, anyone with maybe 60k or more miles on OE mounts, you NEED these. I'm that impressed. Awesome. Time will tell if I can live with the race poly. Short commute so I'm thinking yes. Very excited. Had to post. Can't wait to get em on track. Car feels very connected and solid now. Thanks East Coast Euro. And thanks to Paul at CK Auto in Santa Rosa for the install.
Old May 3, 2019 | 08:13 AM
  #113
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
Before
After (street mounts)
Old May 3, 2019 | 09:17 AM
  #114
Funkwagen's Avatar
2009 C63 AMG, 2010 C250 4Matic Sport
Originally Posted by Jasonoff
These mounts were how I first noticed my front shocks were going bad. The engine didn't move at all on the dyno...the entire car shifted instead
Old May 3, 2019 | 10:56 AM
  #115
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
How are your flex discs after beating on it for a bit? Waiting for my diff to grenade now
Old May 3, 2019 | 10:18 PM
  #116
C63 and CLK55
Glad you are happy with the mounts! The race poly does vibrate more than the street poly. One of the advantages of these mounts is you can swap out the poly if you want to
Great vid illustrating the difference! Thanks
Haha that's awesome
Old May 22, 2019 | 05:16 AM
  #117
jemnoriega's Avatar
2014 C63 AMG Coupe 507 ED
would you still recommend the 40A? I'm planning to put a supercharger soon.
How much for the set?
Thank you soo much ECE for this creation
Old May 22, 2019 | 08:34 AM
  #118
C63 and CLK55
It depends on how you feel about vibration. The race poly will vibrate more than street but should also last longer. The engine mounts are $465 shipped in the USA.
Thank you for the support.
Old Sep 9, 2019 | 07:33 PM
  #119
AMG6.3's Avatar
C63
Hello,
Please PM me costs and availability of the recommended engine and transmission mounts for stock feel.
Old Sep 9, 2019 | 07:58 PM
  #120
C63 and CLK55
Originally Posted by AMG6.3
Hello,
Hello,
Unfortunately we are currently sold out. The engine mounts are $465 shipped in the USA and trans mount is $175 shipped. Thanks
Old Oct 1, 2019 | 09:12 PM
  #121
SROC276's Avatar
2010 C63 P31 AMG
Just installed mine which were sitting out for a while. Absolutely brilliant mounts....car feels planted, noticeably more responsive and smooth shifts with minimal lag. Workmanship was great. I am running the 40a street set. Only very slight vibration at idle otherwise an excellent upgrade and well worth the investment. My stock mounts were perfect and had no issues.
One issue that occurred after install was heavy vibrations and rattles initially. Ahmad was great at providing input to resolve it. My custom IPE center section had to be adjusted several times to compensate for the slightly lower engine height. Helped slightly but didn’t fix the issue. In the end we loosened the cat bolts, center section bolts to relieve tension, then buttoned it up. No more vibrations.
Old Dec 12, 2019 | 09:57 PM
  #122
Nhaf's Avatar
2009 C63 AMG
Hi are the engine mounts still available?
Old Dec 12, 2019 | 10:16 PM
  #123
deadlyvt's Avatar
2010 C63 AMG
Make some more we want em!
Old Dec 12, 2019 | 10:44 PM
  #124
audifreak's Avatar
c63
I want one too
Old Dec 13, 2019 | 09:29 AM
  #125
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
Originally Posted by audifreak
I want one too
You need both...
