Utilising M156 engine and gearbox
I can not find any references to anyone doing this so came here for some advice... hopefully.
My questions are thus:
Can the ECU be utilised seperatley to the BCM with drive by wire systems and instrument cluster or does an aftermarket ECU need to be purchased?
If using the complete wiring harness from the donor car, can system be deactivated from the Canbus system or will this shut down the whole system?
does anyone know if using the M156 or other engines in a different application other than Mercedes bodies?
Thanks in advance,
JB
Search for either "TOYOTAHOLICS AFRICA" page on Facebook, or search for Quentin Boylan and chat to him directly.
Mounting the engine was the easy part
It can be done but to do a unique project take a lot of time, research, and money. I wanted to do a unique car and installed a Viper V10 in an old 1959 big fin Plymouth. I didn’t realize how hard it would be to do the electronics after I had already mounted the engine and was past the point of no return. Talk to serious racers and they may have figured out how to reprogram the computer to ignore everything but the motor. That did the trick for me. It will either run perfectly or not at all. But if you get it right it will be incredible! Good luck.
