Would a bad pcv valve cause oil burning?
I'm trying to decide if I need to bring the car into the dealer or not.
I moved the manifold flap in front of the engine back and forth because I felt it was not moving freely and want to rule that out first. I'm getting some blue smoke on passenger side.its pretty bad after a few min on idle and after I rev it a little. other than that the car runs good and no miss fires or codes |
Intredasted in this too. From my armchair mechanic “research”, the oil get sucked through on decel and liftoff and gets burned on the exhaust. Would a catch can fix the symptoms a bit? Also, does this oil get sucked through cylinder walls? |
I ordered a new valve. Will see what happens
Bad PCV would cause oil burning on both banks equally, no....? :nix:
Originally Posted by Celicasaur
(Post 7461731)
or there is some oil build up in the manifold.will see when I open her up. I hope its nothing serious |
OP good luck with the new valve and please update with results!. Also, whats your approx rate of oil consumption? Ive been filling up 1 L every 2000-3000 KM it seems (mostly driving in M without too much consideration for economy)
Originally Posted by NotABaller
(Post 7461735)
I got the manifold off the car.lots of oil on the side that is burning it.
doing injectors and maybe get some spacers. I have a new pcv valve on the way. https://www.instagram.com/p/BjLtDzEhrDC/?utm_source=ig_share_sheet&igshid=1d6mwatjaxrgq |
Originally Posted by skratch77
(Post 7462213)
https://www.instagram.com/p/BjLtDzEh...=1d6mwatjaxrgqI got the manifold off the car.lots of oil on the side that is burning it.
(Post 7462373)
manifold removal can DIY for beginners? my injectors were really bad |
(Post 7462373)
manifold removal can DIY for beginners? |
(Post 7462373)
manifold removal can DIY for beginners? https://mbworld.org/forums/c63-amg-w...valve-diy.html |
Make sure you open up the manifold and clean it up also.
(Post 7463251)
Originally Posted by iShootYou
(Post 7463648)
when you open the manifold what do you use to reseal it or do they sell a gasket kit. you will need new gaskets that go on the engine block between the manifold tho. here is a video of the inside. |
(Post 7463891)
There is one rubber gasket around the throttle bodies but it pretty heavy duty so I'm not changing it.
you will need new gaskets that go on the engine block between the manifold tho. here is a video of the inside. https://youtu.be/MI6d-H62CaQ |
(Post 7464193)
I've replaced my IM Gasket before, I was just wasn't sure about the gasket in the IM. Are you planning on hot tanking the IM, if not how do you plan on cleaning it?
(Post 7464249)
I spent about an hour wiping it down with rags and let it sit for a day to let all the oil drip out the runners
Originally Posted by Saurabh914
(Post 8047033)
Hey, I know this thread is 2 years old but did the new PCV fix the issue? I’m have the same issue but when I accelerate from a stop light blue smoke comes out. And I’m leaking oil from the passenger side so maybe it’s my PCV.
I would also check your oil level and make sure you don't have to much oil in the car. |
(Post 8047151)
Yes it will help but you definitely need to clean your intake manifold out and install a catch can.
Hello I am having oil consumption issues! Well I think. First 600 miles 1L. Then it said add 1L after 300 Milea, then this last time it said add 1L after 120 miles. Drive it straight home from the office and let it sit. It said 'Oil Level Ok'. The. Next day I went to the on board computer and it says Add 2L. Without any driving.
The vehicle runs great with no lack of power. I ordered a new sensor on the way but it could also be the PCV Valve. But where can I buy one? i cannot find anywhere. |
^^ FCP Euro 5/5
Ya FCP got mine there last year.
Would someone be able to send me the link? I cannot find on FCP. w211 2005 E55 AMG.
It keeps saying item not found. |
you're on the wrong forum. this thread is for the M156 engine not the M113k.
