Amg front caliper piston link pipe
https://cimg5.ibsrv.net/gimg/www.mbw...db045c665c.jpg https://cimg6.ibsrv.net/gimg/www.mbw...4da22cd1b3.jpg does anyone know where to source the above without buying a whole new caliper? I know the calipers look similar to others but are they actually the same ? If so what makes ? Im in the uk and was due to hit the ring next week so that won't be happening now I'll get some pics uploaded later but it's the small pipe that goes between the two banks of pistons at the bottom of the caliper mine burst underneath the rubber pipe that's on there to stop it rubbing it was rusty as underneath thanks |
https://youtu.be/j0lkvdK5iak hopefully the link will work |
Contact Brembo directly while you're at it. You definitely won't be the first person to be looking for these.
Brunty, try Think Automotive in Ashford. Take your pipe with you to them and they'll make you the fitting on site and it probably won't cost much more than about £20-£30 tbh.
It would be a pretty easy pipe to make with a flaring tool and a couple correct sized threaded ends - any shop that makes custom brake lines could knock that out in 30 minutes.
This is a place in the UK that refurbs them and makes the pipes https://brembo-caliper-refurbs.uk/pa...ossover-pipes/ These may also work for you https://www.ebay.co.uk/itm/Porsche-C...MAAOSwmQBZiQYf |
Originally Posted by roadkillrob
(Post 7469186)
This is a place in the UK that refurbs them and makes the pipes https://brembo-caliper-refurbs.uk/pa...ossover-pipes/ These may also work for you https://www.ebay.co.uk/itm/Porsche-C...MAAOSwmQBZiQYf I’ve ordered those off eBay but ideally I’d like the proper brembo ones I’ve contacted them just waiting on a reply but I’ll look into the refurb company |
