SLS Wheels on C63 Coupe?
Has anyone installed SLS wheels on a C63? SLS offsets 9.5 x 19 60MM offset Fronts ,11.0 x 10 68MM offset Rears. Can get a set but not sure of the offsets. Thx for the help
Sounds like a sexy idea if it works!
I can't see them fitting without problems.
What size tires do you intend to fit? . |
Regardless of the tire size. I don't believe you can even install the wheels. Offsets are way too high and rim is way to wide. The wheel would hit the suspension before you can even bolt it in.
Talked to wheel retailer and they told me the rear will not fit. Too bad, found a C63 owner with this style but he used replicas and car looked good. Link to wheels below
https://sfbay.craigslist.org/sfc/wto...610968011.html |
Originally Posted by America
(Post 7487438)
