Car Won't Start No Matter What.
2009 C63 AMG, 2013 CLS63 SAMG, FORD F350, BMW 750LI
No, the car is smart. If there is not enough voltage the car basically says "no way. voltage is too low. I'm not even going to bother doing anything." Even my Ryobi power tools do that. once the battery is at a min voltage, the tool shuts off. You should try a brand new battery. having to get the battery charged up sounds like the battery is bad.
A fully charged battery diagnosed as "fine" virtually unused drained down to 9V in less than a week is not "fine" by any means.
You have some crazy parasitic draw somewhere if that battery is actually "fine".
This seems pretty silly that this has gone on this long. K.I.S.S. It's the battery.
1. Remove current inoperable battery.
2. Install known working battery which can crank over another vehicle.
3. Fire it (the AMG) up.
4. Buy new battery as you've now proven the other "new" battery is "bad".
Towing was a pain, the car wouldn't shift into neutral at all.
I don't know how they ended up towing but eventually they got the car in neutral but the steering locked up with the wheels turned to left. So they couldn't even push it straight!
The dealership put a new battery in, it got some power but eventually died again. They said its a wiring issue from the battery going to the front.
They found the issue and fixed it but now the car starts and misfires with rough idles!!!!
This time i left it for a 2-3 weeks and it dies.. which makes no sense especially when the battery is new.
But now the car is having misfires and rough idles!
#32
#33
Damn man, sorry to hear about these issues. Friggin electrical gremlins are the worst! Good luck and hope you get it sorted. I haven't looked it up myself but there's gotta be a manual mechanism to release the shift lever to put in neutral as a failsafe. Probably in the manual. Usually you have to turn a hidden lock under the shifter trim etc.
#34
The following 2 users liked this post by chrisridebike8:
Crya (11-01-2018),
Jacked a c63 (11-02-2018)
#35
But the tow truck guy just came and put the car on go jacks LOL because the steering wheel was still locked and still couldn't turn left or right. So then he manually pushed it into the street and then towed it to the dealership.
The car starts but still has stupid rough idles, they haven't figured out why. And they said something is still draining the battery, they have to find the electrical issue.
#37
My headlight switch was draining my battery when it was in Auto. When it was Off, it didn’t. Maybe switch it to Off and see if that helps. If it does, the switch is easy to replace.
#38
#39
I thought maybe it was the parking lights or eyebrows but the dealership said thats very unlikely.
