"Replace brake pads" on dashboard, how do I know if it is rear or front?
Hello,
Is there an "electronic" way to know which pads need to be replaced, without fancy scanner? Thanks! |
I use an eyeball and a flashlight.
you should be able to spot pad thickness if you look its fairly easy with multi piston brakes like our cars have.
Originally Posted by Crya
(Post 7673677)
Most auto part stores sell a small plastic brake pad measuring tools that you can buy.
This tool has prongs that are Green, Yellow and Red that measure the pad thickness accordingly. If its Green your good to go, Yellow your good for now, but will require attention in a little while, Red needs changing right away. https://www.autohausaz.com/pn/81850L...xoCr40QAvD_BwE |
Originally Posted by Jasonoff
(Post 7674155)
Which eyeball?
Originally Posted by Yuille36
(Post 7674345)
Your calibrated eyeball :smash:
Dang, I haven't been to a LIMB clinic to get my augmentations updated. I'm sure I'll need a recalibration, I'll have to check if I have some praxis laying around. If you get that reference that's +10 points. |
9 times out of 10, it's your front pads, as 70-75% of the braking force is done by the front brakes, as they wear faster than the rears. Put a complete check of the the brake pads are warranted.
Originally Posted by Adi-Benz
(Post 7674354)
(Post 7674378)
I completely forgotten about that fact, thank you.
Just did mine this week... 2hrs per corner including cleaning everything!! Easy pesy... got all four corners pads and rotors $1200... street car no track use
https://cimg9.ibsrv.net/gimg/www.mbw...b2d181ff0d.jpg |
