Coilover spring rate question !
Hi guys , i have question about spring rate ? What is rexommended spring rate for coilover ... i dont really do track ... and i want someting not tooo stiff .... i have read a lot and i didint see a real answer ... thanks !
There isnt any manufacturer that does a custom spring rate from front to back. BC and fortune autob only does in front so it isnt really ideal. if you want a softer set up than non pp then i can suggest koni yellow shocks. They are softer but yet still retain proper damping and is really good for DD. Koni doesn’t make for c63. Im using the ones for regular w204. Total price i got was 750 for shocks. that also open up kw confort serious and bilstein for the regular w204 |
I buy kw ... they make costom spring rate front rear and apropriate valving so ...
From AMG3.2’s build thread. https://mbworld.org/forums/showpost....&postcount=245 https://mbworld.org/forums/showpost....&postcount=274 |
Originally Posted by jsorodm2010
(Post 7677733)
Originally Posted by BLKROKT
(Post 7677829)
Well then ask KW |
