Oil temp reading "---" or 0 and oil cooling fan on - MBWorld.org Forums
Go Back  MBWorld.org Forums > Mercedes-Benz AMG Vehicles > C63 AMG (W204)
Oil temp reading "---" or 0 and oil cooling fan on >
C63 AMG (W204)
Old 02-11-2019, 01:58 PM
SROC276's Avatar
2010 C63 P31 AMG
Anyone experience this issue? My oil temp sensor read 0 today and oil cooling fan ran for about 2 minutes after parking. Oil in engine not an issue. Can we confirm the fan was on because of a fail safe and not anything else other than a failed sensor. Its been a real weird sensor....oil temp readings were all over the place and never seemed to get to operating temp. Ive read through forums and the story never completes so not sure what the final fix was for other folks. Hoping just the sensor and fan was a failsafe measure. Thanks for any input.
SROC276 is offline
Old 02-11-2019, 02:14 PM
Jasonoff's Avatar
2010 C63 AMG
Try cleaning the temp sensor connector. The fan on is normal when it doesn't know the temp reading.
https://mbworld.org/forums/c63-amg-w...ing-crazy.html
Jasonoff is offline
Old 02-11-2019, 02:55 PM
Yuille36's Avatar
07 E63 AMG, 10 C63 AMG, 07 E63 Designo, 07 E350, 09 C300, 07 C230
I had a similar issue in my 07 E63, the oil temp sensors temperature was fluctuating over the place, so I ordered a new one. Once it arrived, I took my car into to Benz elite Automotive in Fairfax, VA to have them diagnose via Star Diagnostics. They ended up changing out the oil temp sensor which isn't easy to get at on a M156 engine, as it resides behind the AC compressor. The sensor was replaced, and they took the car for a test drive, when they returned the primary oil cooler fan was on, and the oil temp showed 215 degrees, which we know wasn't right. So we again replaced that sensor we a new one, then had the sensor reset via Star.
Now my oil temperature ran at about 81 degrees Celsius before the swap, now it run about 87 degrees Celsius which equates to 187 degrees Fahrenheit. And I haven't had any further issues.
So my suggestion, would be to have someone diagnose it with Star Diagnostics. And replace the oil temp sensor, which isn't easy to access or cheap to repair, as it's the labor that gets you.
Yuille36 is offline
Old 02-11-2019, 03:21 PM
SROC276's Avatar
2010 C63 P31 AMG
Ok thanks
SROC276 is offline
Old 02-11-2019, 03:22 PM
SROC276's Avatar
2010 C63 P31 AMG
Ok got it....yes working on that today...I was more concerned that the fan stayed on....sensor has been ordered.
SROC276 is offline
Old 02-12-2019, 12:50 PM
Yuille36's Avatar
The fan isn't the issue, its the sensor sending back mis-information to the ECU which is telling the fan that your oil is too dam hot, so turn on the fan to cool it down.
Yuille36 is offline
Quick Reply: Oil temp reading "---" or 0 and oil cooling fan on
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Your question will be posted in:
