C63 AMG (W204) 2008 - 2015
Removing these things without damage?
Old Oct 18, 2019 | 07:44 PM
JumboNate's Avatar
2015 (Final-Year) Fully-Loaded W204 M156 Custom Mercedes-Benz Designo C63 AMG Edition 507 Coupe
Question Removing these things without damage?
Good evening.
As you can see in the attached picture, the previous owner of this car was a Freemason.
To the left of the license plate are metal-ish badges. I can't pull them off.
I believe that they are glued on somehow. My question is, how can I remove these without damaging the paint on the car? I've only thought of using fishing line or a heat gun, but, I don't own a heat gun.
What can I do?
- Nate
Badge-removal
Old Oct 18, 2019 | 08:14 PM
roadkillrob's Avatar
Top Answer: 1
12 C63BS Magno Alanite Grey, 25 X5 Msport, 08 BMW E93, Ducati Hyper 698
Dental floss or light fishing line and just work it back and forth behind the emblem, it will cut through the foam adhesive without any damage to the paint, then you can just work off the remaining adhesive with your fingers, a little heat will help.
Old Oct 18, 2019 | 08:25 PM
curt.r's Avatar
2013 P31 C63 Sedan
Originally Posted by JumboNate
Good evening.
What can I do?
- Nate
Badge-removal
A heat gun is fairly inexpensive, and saves a bunch of time cleaning up the adhesive. Sometimes you get lucky and with the right amount of heat, the two sided tape peels up with the badge. I own the older model of this one:
Wagner Heat Gun Wagner Heat Gun
. I would definitely recommend getting one. They've come in handy more times than I can count. Anyways, like roadkillrob said, I would use light fishing line paired with a heat gun. I've found dental floss does not work. If you really want to remove the adhesive quickly and not deal with using goo-gone, get one of these:
3M Eraser Wheel 3M Eraser Wheel
. Otherwise, I use Goo Gone remove the adhesive left behind by the tape (which is a major PITA btw):
Goo-Gone Adhesive Remover Goo-Gone Adhesive Remover
. Hope this helps.
Old Oct 18, 2019 | 08:41 PM
Adi-Benz's Avatar
2010 C300 4MATIC........ 2011 C63 AMG.............. 2015 CLS400 4MATIC.....
Use your wife's hair blow dryer
Adi-Benz's Avatar
WD-40 will work as well, spray and let it soak for 10-15 min
Old Oct 18, 2019 | 08:56 PM
JumboNate's Avatar
If only I had a wife...
Old Oct 18, 2019 | 08:58 PM
JumboNate's Avatar
Originally Posted by curt.r
A heat gun is fairly inexpensive, and saves a bunch of time cleaning up the adhesive. Sometimes you get lucky and with the right amount of heat, the two sided tape peels up with the badge. I own the older model of this one: Wagner Heat Gun . I would definitely recommend getting one. They've come in handy more times than I can count. Anyways, like roadkillrob said, I would use light fishing line paired with a heat gun. I've found dental floss does not work. If you really want to remove the adhesive quickly and not deal with using goo-gone, get one of these: 3M Eraser Wheel . Otherwise, I use Goo Gone remove the adhesive left behind by the tape (which is a major PITA btw): Goo-Gone Adhesive Remover . Hope this helps.
Thank you!!
I really appreciate the reply with the links included
Old Oct 18, 2019 | 08:59 PM
BLKROKT's Avatar
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
They’re attached by magic. They can’t be removed without getting cursed, sorry.
Old Oct 19, 2019 | 09:14 PM
CyanideRide's Avatar
S/C C63
Use one of these to clean up the gunk left behind.
https://www.amazon.com/Remover-Stickers-Minutes-Wheel-toolkit/dp/B00VFACQRE/ref=pd_sbs_263_t_0/138-6580234-2360459?_encoding=UTF8&pd_rd_i=B00VFACQRE&pd_rd_r=c1a689dd-0d71-482d-b29a-cb3fa9bf047b&pd_rd_w=rIm9B&pd_rd_wg=vxDth&pf_rd_p=5cfcfe89-300f-47d2-b1ad-a4e27203a02a&pf_rd_r=DEH308MP7AHG1NTKG00S&psc=1&refRID=DEH308MP7AHG1NTKG00S https://www.amazon.com/Remover-Stickers-Minutes-Wheel-toolkit/dp/B00VFACQRE/ref=pd_sbs_263_t_0/138-6580234-2360459?_encoding=UTF8&pd_rd_i=B00VFACQRE&pd_rd_r=c1a689dd-0d71-482d-b29a-cb3fa9bf047b&pd_rd_w=rIm9B&pd_rd_wg=vxDth&pf_rd_p=5cfcfe89-300f-47d2-b1ad-a4e27203a02a&pf_rd_r=DEH308MP7AHG1NTKG00S&psc=1&refRID=DEH308MP7AHG1NTKG00S
I used the exact same one on my C when I removed that @#$%ing factory spoiler and all the gunk that was left behind came off like magic.
It makes a bloody mess, but it got everything off with relative ease and the use of a drill. Didn't even harm the paint one bit.
