Head bolt Replacement Timing issue please help
So i did the 1 by 1 method and replaced all the bolts, intake camshafts and lifters, however when putting it back together I got a bunch of codes thrown and the car misfires all on bank 2.
Steps taking so far
-Used 2 timing templates at the same time at 40 deg (all plates and bars in place on both sides before tightening.)
-Took off bank 2 cover again, found the exhaust was a bit misalligned due to a worn pin in the gear, took apart gear, did the pin flip, reassembled with new washer and bolt.
-Removed camshaft sensors and cleaned a bit of metal paste type stuff on them off and reassembled.
This just made it even worse... Bank 1 seems to run fine, but bank 2 will keep trying to find timing and eventually just run like crap.. Any help or troubleshooting steps would be much appreciated.
Car ran fine before the process. I'm guessing I did something wrong with the timing? but I'm Unsure.
