C63 AMG (W204) 2008 - 2015
Any value in used stock injectors?
Old Feb 16, 2021 | 12:46 AM
See63Run's Avatar
2013 C63 (W204)
As the title suggests, I’m wondering if there’s any value in my used stock fuel injectors. I replaced mine last night and with 87k on them, they were pretty dirty (see photos). I know it’s possible to send them and have them cleaned and flow checked, but that was almost expensive as buying them new. Any reason I should keep them?
Old Feb 16, 2021 | 02:04 AM
BLKROKT's Avatar
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
If you ever find yourself needing a fuel injector, you’ll have your answer.
It’s a small box to hold 8. No harm in keeping it.
Old Feb 16, 2021 | 03:27 AM
hachiroku's Avatar
SPONSOR
2007 Mercedes E63 AMG
there is no market for used factory injectors as some have been shown to fail, but as Jim mentioned, they don't take up much space, so might as well keep them.
__________________
-BARRY
​​​Follow us on instagram @eightysixtuned
https://www.eightysixtuned.com
Old Feb 16, 2021 | 07:34 AM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
Those look fkn nasty.
Old Feb 16, 2021 | 08:01 AM
See63Run's Avatar
2013 C63 (W204)
no kidding. Exactly why im glad to have changed them
Old Feb 16, 2021 | 08:29 AM
roadkillrob's Avatar
Top Answer: 1
12 C63BS Magno Alanite Grey, 25 X5 Msport, 08 BMW E93, Ducati Hyper 698
If there was a market for used ones, probably. not those ones, those look terrible - was definitely worth changing them.
Old Feb 16, 2021 | 08:38 AM
chrisridebike8's Avatar
'10 C63
Did you get the bosch ones for like $25 each? I did that a few years back and had 2 leak. I wish I had saved my stock ones and had them cleaned. Stock ones were like $100 each other something. SAVE THEM!
Old Feb 16, 2021 | 09:05 AM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
Were you getting misfires?
Old Feb 16, 2021 | 10:21 AM
BalanBro's Avatar
2012 C63 P31 Sedan
Wow, I guess I should definitely change mine out. I'm only at 53k, but I'm surprised they look like that at only 80k. Thankfully I picked up my full set from FCP Euro last year for $161.
Maybe you can try soaking them in a small container of fresh gasoline and P.E.A. based fuel system cleaner for a few days and see if it can dissolve off the crud. If you can get them reasonably clean, it may be ok to keep as a backup.
Old Feb 16, 2021 | 07:08 PM
'10 C63
no. My oil temp reading was bouncing around all over place. So i pulled the fuel rail out of the intake manifold and turned the key to on to let the fuel system prime and saw 2 of the injectors leaking. Not terribly like a gush, but just some consistent drips. That was about 7-8k miles after putting them in. Once i swapped all the injectors out, the oil temps stabilized. Also, no leaks from the new injectors.
Old Feb 16, 2021 | 07:46 PM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
I'll keep an eye on mine. Car is track only and they've been in one full season.
Maybe you just got bad stock?
Old Feb 16, 2021 | 09:50 PM
See63Run's Avatar
2013 C63 (W204)
Yes, I got the Bosch ones and they were about $31/each. It was my understanding that Bosch injectors are OE for these cars. The ones I took out were Bosch.
maybe I will have these professionally cleaned and keep them in my garage.
